hello I have a problem with managing artists and albums in the library with .wav files with Volumio 2.348. The artist recognizes me but does not divide the albums, then incorporates all the files. Which solution do you have? thank you
Hello but nobody had the same problem? No one uses .wav files on Volumio?
up
I have the same. Probably not many people suffering this issue.
It’s quite irritant!
why use it? if you have multiple other formats that will work great
I have a library with lots of .wav files. They do not have tags by definition. I know it is my problem, not Volumio’s, should have taken another format (flac) when I ripped my complete CD collection.
Perhaps, some day, I will do them all again…
Has there been any progress on this issue? I have the same problem .wav files play beautifully, but loads into one album…very annoying that this fantastic software does not have this basic sort functionality. I too believe that the .wav format is more applicable to my needs, a shame this has not been implemented.
