updated the khadas tone board firmware, now it only disconnects and stops, it will now continue playing when I select the khadas again in Spotify for example.
as soon as the connection with the dac is lost you will get the following.
[Vollibrespot] : Setting up new mixer: card:hw:5 mixer:Tone1 index:0
see section log!.
Starting Live Log...
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
[Vollibrespot] : Connecting to AP "******************"
[Vollibrespot] : Authenticated as "***********" !
[Vollibrespot] : Alsa min-db is not SND_CTL_TLV_DB_GAIN_MUTE!!
[Vollibrespot] : Alsa Mixer info min: 0 (MilliBel(-12700)[dB]) -- max: 127 (MilliBel(0)[dB]) HW: true
[SpotifyConnect] 100
[SpotifyConnect] Volume: Spotify:100 Volumio: 100
[Vollibrespot] : Using alsa sink
[Vollibrespot] : Metadata pipe established
[Vollibrespot] : Country: "NL"
[Vollibrespot] : Event: Volume { volume_to_mixer: 65535 }
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: SessionActive { became_active_at: 1620747928406 }
[Vollibrespot] : SessionActive!
[SpotifyConnect] A connect session has begun
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 84781842612720230375261977081072073254, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 84781842612720230375261977081072073254, audio_type: Track } }
[SpotifyConnect] Device palyback is active!
[SpotifyConnect] Currently active: webradio
[SpotifyConnect] Stopping currently active service
info: CoreCommandRouter::volumioStop
[Vollibrespot] : Loading with Spotify URI
info: CoreStateMachine::stop
UNSET VOLATILE
[SpotifyConnect] Vollibrespot Active
[SpotifyConnect] Setting Volatile state to Volspotconnect2
[Vollibrespot] : No autoplay_uri found
[Vollibrespot] : AutoplayError: MercuryError
[Vollibrespot] : Event: GotToken { token: Token { access_token: "BQCx3lR2JJv6xj3pd_XM61T2rba_ttnlB1LQuhMqBxJIHnDzedBJ-UgdojkfodeMYByeGGOFl_mOcrHJpppDEK7DzYgsN8qCFAyEPpfKCCO3GyNQaNHUOeJIqHcTGllstM8fAgqB1n1w-CRkCfM6749i_je3nOfX5KNhAIZa", expires_in: 3600, token_type: "Bearer", scope: ["streaming", "user-read-playback-state", "user-modify-playback-state", "user-read-currently-playing", "user-read-private"] } }
[SpotifyConnect] Currently active: volspotconnect2
[SpotifyConnect] Pushing new state :: true
[SpotifyConnect] BQCx3lR2JJv6xj3pd_XM61T2rba_ttnlB1LQuhMqBxJIHnDzedBJ-UgdojkfodeMYByeGGOFl_mOcrHJpppDEK7DzYgsN8qCFAyEPpfKCCO3GyNQaNHUOeJIqHcTGllstM8fAgqB1n1w-CRkCfM6749i_je3nOfX5KNhAIZa
[SpotifyConnect] Setting VLS device_id: b29c9acf1f459114b9a515c5d1088bb14faa82df
[Vollibrespot] : (201038 ms) loaded
[SpotifyConnect] Device palyback is inactive
[SpotifyConnect] Device Session is_active: true
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 84781842612720230375261977081072073254, audio_type: Track } }
[Vollibrespot] : Event: Play { track_id: SpotifyId { id: 84781842612720230375261977081072073254, audio_type: Track }, position_ms: 4 }
[SpotifyConnect] play
[Vollibrespot] : Event: SinkActive
[SpotifyConnect] Penelope
[SpotifyConnect] Pushing metadata
[SpotifyConnect] Sink acquired
[Vollibrespot] : Event: Next { track_id: SpotifyId { id: 20064934123730160124159430274025423432, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 84781842612720230375261977081072073254, audio_type: Track }, track_id: SpotifyId { id: 20064934123730160124159430274025423432, audio_type: Track } }
[SpotifyConnect] Thirteen
[Vollibrespot] : Event: SinkInactive
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 20064934123730160124159430274025423432, audio_type: Track } }
[SpotifyConnect] Sink released
info: touch_display: Setting screensaver timeout to 0 seconds.
[Vollibrespot] : (184869 ms) loaded
info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
[Vollibrespot] : Event: Next { track_id: SpotifyId { id: 105246080475623257651896384782742726577, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 20064934123730160124159430274025423432, audio_type: Track }, track_id: SpotifyId { id: 105246080475623257651896384782742726577, audio_type: Track } }
[SpotifyConnect] Frost
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 105246080475623257651896384782742726577, audio_type: Track } }
[Vollibrespot] : (324107 ms) loaded
[Vollibrespot] : Event: Next { track_id: SpotifyId { id: 196322758445766552688181909277329741768, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 105246080475623257651896384782742726577, audio_type: Track }, track_id: SpotifyId { id: 196322758445766552688181909277329741768, audio_type: Track } }
[SpotifyConnect] Follow You
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 196322758445766552688181909277329741768, audio_type: Track } }
[Vollibrespot] : (192156 ms) loaded
[Vollibrespot] : Event: Next { track_id: SpotifyId { id: 263284360199753733096833996249869609211, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 196322758445766552688181909277329741768, audio_type: Track }, track_id: SpotifyId { id: 263284360199753733096833996249869609211, audio_type: Track } }
[SpotifyConnect] Synapsis
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 263284360199753733096833996249869609211, audio_type: Track } }
[Vollibrespot
