I have a bit of a problem with Volumio 1.5.
After I install the image I have no problem playing files in any bitrate or resolution however after a while something changes and I couldn’t play the CD quality 44.1kHz and DSD files without setting the resampling in the MPD config section of the user interface.
The high res files always play without problem.
I have tried to reinstall volumio several times but the same happens every times.
I really would like to hear the files without resampling thus loosing some SQ.
I could live with resampling the CD quality files but I surely don’t want to resample the DSD files.
I am using a Cubox-i4Pro feeding my Jolida Fusion 3502 amp through a Yulong Sabre DA8 DAC.
Thanks for your kind help.
