Hi …
I’ve been using my PI 4 for a couple or month now, simply listening to my music stored on a 2Tb external USB HDD, directly connected to one of the pi4 USB ports, no problem.
I listen with a headphone pluged in the iqaudio hat installed.
Volumio (2.917) software IS stored on the micro SD,
Only flac files on the HDD.
Now I’ve got a brand new Samsung T5 SSD, fat32 formatted, and copied all my music on it with my PC.
This new T5 is cable wired on one of the pi4 usb3 terminal.
For some reason I don’t understand, the T5 is not detected or recognised automatically on the USB !
IS there anything special to do be able to access a SSD?
I’ve gone through the complete resetting of volumio, still stuck there.
I guess I’m not very much talented in debian, linux etc, but I’m a bit disappointed by that kind if issue.
I’ve read here and there plenty of good things about SSD and Pi … and ok … I guess this is an already documented issue.
I juste did some more going back and forth from HDD to SSD.
HDD is automatically detected and scanned, but absolutely nothing for my Samsung T5 2 tb.
I’ll stay with the hdd and wait for an update …
Cheers
JMIK
What kind of partition table does both drives use? It could be the difference between MSDOS and GPT partitioning. Or the the SSD is using hardware 4K blocks while the fat32 driver is expecting 512B blocks. I see that this model is USB powered maybe it asks too much power and would a using a USB hub the solution.
My 2Tb HD (working fine) was Fat32 formatted on a PC.
This new SSD was originally exfat formatted in its box. As I’ve tried it like this on the pi4 with some music files and could not access them, I performed a fat32 using the guiformat tool on my PC.
I don’t think power is the issue as this SSD is supposedly using much less than the HD, and recommended for standalone use.
I’ve read here and there users writing good things about this Samsung T5 unit, I’d be glad to know how they’re using/format it !
Ok, maybe I should partition this SSD using gpart under debian?
But, will the SSD be accessed without issue on a Windows PC whilst updating my music files ?
The ssd will eventually be shared with samba (unless you are wanting to remove it & physically connect it to your PC to transfer files), and so it shouldn’t matter how it is formatted as long as your RPi is able to read it. Windows will just see a network share and won’t be bothered what the underlying filesystem is.
Hi again
And thank you for your help.
I found lots of posts on my concern with google’s help.
For various reasons, what matters most for Me is just to be able to read audio files on my pi 4 and volumio, no need to be able to write with the pi.
And then, What I need is to be able to read/write on any Windows PC.
From what I understand, NTFS format should be fine and simple enough for me.
Right,?
Formatting as FAT32 should actuallly be ok.
It may be helpful if you could produce a log, perhaps there is another reason why this unit is being skipped.
Why do I get the feeling that you plugged in the Samsung T5 approx. 40 secs after you sent the log
Could you boot without the hdd connected, let it run for 10 minutes, then reboot with the T5 connected.
Or insert after boot, but do not send a log before the T5 is connected.
