Hi everybody,
as I wrote in my introduction Post, I Upgraded my Pi Model A to a Pi 3.
I’m running Volumo 2.368
I created a backup from the old Installation with the Backup Plugin and loaded it into the new setup Pi 3.
The Mount was also copied.
But instead of the same NFS Path as on the old device, it showed the CIFS path, Windows like.
The NAS is called “musikbunker” and the Share is “Musik”
So the NFS Share was mounted as “musikbunker:volume1/Musik” and on my Pi 3 it gets mounted as “\Musikbunker\volume1/Musik”
Also the Size of the Share gets detected wrong. On the Pi1 it was about 1.5 TB and now it is only about 600 MB.
Even if I delete the mount and set it up new, it’s mounted like I described above.
Has anybody any Idea, what is going on?
Greetings Sascha
