Hi, I’ve problem installing plugin, every plugin which I try to install stops at 10% install progress. I saw few topics with similar case but I can’t find any useful port. Please help
root@volumio3:/home/volumio/lab# cd volsimpleequal
root@volumio3:/home/volumio/lab/volsimpleequal# volumio plugin install
This command will install the plugin on your device
Compressing the plugin
Plugin succesfully compressed
Progress: 10
Status :Downloading plugin
Downloading plugin at http://127.0.0.1:3000/plugin-serve/volsimpleequal.zip
I deleted zip files prepared by instalator and then over sudo install command but still no success
volumio@volumio3:~/lab/volsimpleequal$ sudo volumio plugin install
Progress: 10
