I boght new display from waveshare 3,5 LCD B. it connected via gpio and backlight is working.
but, nothing more. I tried to install drivers from github a lot of time, but still same result.
the system felt down and by next boot some where stoped. for was neccessery reinstall system again.
I would like to ask if has sombody the same experiences and some solution.
I suggest to start with a fresh Volumio version (BTW: What is your Volumio version?).
Then nstall the Touch Display plugin from the plugin store.
Don’t run the install script from Waveshare. You will have to do some adjustments to /boot/userconfig.txt and maybe some other files, too. We can do this step by step.
What is necessary depends on the model of your display.
