Problem .2 fail 1 error
Hi Guys,
I’m getting exactly the same error when trying to boot into volumio.
I’ve downloaded the zip file containing the image to my mac, unzipped it, created a bootable SD card from it using ApplePi-Baker, inserted the SD card into my Raspberry Pi 2 Model B and then I just get the error reported above after a a bit of script rolls across the screen and nothing else happens.
What am I doing wrong? I can’t find anything about this in the FAQ or in previous forum posts.
cheers
The ext-4 fs asks you to perform a fsck to check the filesystem. Not a showstopper.
The 802.11… failed message has something to do with Wi-Fi
