So this weekend I upgraded my pro-ject streamer s2 ultra to the latest build and now I am unable to natively play DSD files. has any one experience the same issue? I have an Amanero combo384 and before the update DSD was fine. I can play DOP ;however, after a few min of playing I lose my USB drive where I keep my dsd files.
Correction - the USB drive is present is just the the app on my phone is not formatted correctly and it cuts off the USB drive from the screen. Still unable to play native DSD, only DSD over PCM.
Why not delete the app on your phone then reinstall ? Better turn off the S2 Ultra before you remove and replace the app. Then turn on the streamer before you start up the app.
