I’m using the Pro-Ject Streambox S2 Ultra, which runs a version of Volumio (which I’m familar with after previous using Volumio with an RPi). I prefer to run the streamer as a DLNA renderer, controlled with JRiver Media Center. I found initially that this was not working properly - any track I played would stop after 10 seconds. I then found that if I set JRiver to ‘Disable SetNext Support’ then it works okay, but without gapless playback. So I guess Volumio does not currently support SetNext?
Updated last night to latest version (1.038) but problem persists
Thanks for reporting, we are investigating
Just updated to the latest version (1.041) and can confirm that this issue is fixed! Awesome stuff - thanks!
Just curious…
Are the features similar to a standard Volumio installation?
Can I just install a regular volumio version?
Thanks.
Thomas
I don’t have the current version of Volumio installed on another device to compare - at the very least, updates do not seem to come at the same time - but otherwise I assume they’re more or less in step.
Before I picked it up I read comments from John Westlake (the designer) to the effect that users would be able to install their preferred distro (which would include Volumio proper), but there’s no documentation on how to do this and I haven’t tried to figure it out, though would like to.
Hi there. I seem to have lost gapless playback with a recent update of the Project Play app. Using it for streaming Tidal only. Very slight hesitation between tracks that flow into each other. Otherwise all good. I’m new here. Should I post elsewhere?
Cheers
