Volumio Version:115
Hardware: pro ject stream box s2 ultra
DAC: quad altera play
Hello dear connoisseurs, my DAC does not see the streamer, only when I pull the cable USB out of the streamer (with the devices turned on), and then return it back, the DAC sees the streamer, replacing the usb cable does not help, after turning off one of the devices, I need to reconnect the cable again, what to do? Thank you.
It’s not detected on start (I see from the logs) but I don’t see any error either…
Sorry but don’t know what it can be…
Since this behaviour seems pretty unique to the QUAD unit, I suggest to ask QUAD again if they have any hint…
