Primo Plus or NUC/Precisio
I am currently using Volumio on a trial basis with a NUC and Eversolo a6 as a DAC. I would like to ditch the Eversolo and am considering the Volumio Primo Plus. But then I wondered if Volumio on the NUC with a Precisio would be a better option.
What do you all think? Are there even better options?
Thanks,
Chris
The Primo Plus essentially integrates the Preciso DAC stage (dual ESS ES9039Q2M in a dual‑mono layout), but there are some differences in overall design and implementation.
The Primo Plus is a complete streamer with a lifetime Volumio license, while the Preciso is a standalone DAC only.
Also worth noting: your NUC is likely the weaker link in the chain, mainly due to potential electrical noise and active cooling (fan). The Primo Plus, being fanless and purpose-built, avoids those drawbacks.
As for which is the better choice, that really depends on your budget and sonic preferences, there’s no one-size-fits-all answer here.
But back to your ask, I would opt. for the Primo Plus.
@Wheaten
Thanks for the pointers. I’m nearly there with the Primo Plus. I’ve been enjoying Volumio on NUC. It has been very solid on my network. But I do want to get rid of the monthly charge. At this point I see no reason to get the Vivo/Preciso.
