Hi, need some assistance
My Primo Plus can’t connect to Qobuz Connect. Qobuz is recognizing Primo Plus but it just don’t connect. Others having this issue?
Thanks in advance
Thanks in advance
I have also noticed that on 24/192 albums some tracks aren’t able to be played in Qobuz - As an example; Albert King with Stevie Ray Vaughan “In Session” first track can’t be played.
Anyone else noticed this issue?
I can’t replicate issues with the Primo Plus and Qobuz Connect.
Just tested, but it’s playing fine.
{"status":"play","title":"Old Times (Album Version)","artist":"Albert King","album":"In Session (Album Version)","albumart":"https://static.qobuz.com/images/covers/29/71/0088807237129_600.jpg","uri":"","trackType":"qobuz","codec":"","seek":9849,"duration":76,"samplerate":"192 kHz","bitdepth":"24 bit","channels":2,"random":false,"consume":false,"volume":66,"dbVolume":null,"mute":false,"disableVolumeControl":false,"stream":false,"updatedb":false,"volatile":true,"service":"qobuzconnect"}
@volumio
Any suggestions?
I have the RivoPlus, and yesterday got error messages from Qobuz stating that a couple of tracks could not be played. They were high res tracks. Perhaps a Qobuz issue?
I encounter the issue not being able to play an entire album - the problem is both on some 24/96 and 24/192. Is this an Qobuz issue or Volumio issue or a combination of both? It’s just until recently that this issue seems to occur. A bit annoying to say the least!
Interested in hearing if others also encountered this!?
it is a Qobuz issue, we have been notified by them about it
Thank You for confirming Darmur
Hope they get it solved as soon as possible!
we hope so! unfortunately there is nothing we can do about it, just wait for them to fix
