Primo and Linao5 positioning
I have a little question about the Primo and Lineo5: is it safe to stack them on top of each other, ie: the Lineo5 at the bottom and the Primo on top? They are both 27 cm in width, I have no room to put them side by side. Thank you so much!
yes you can do that without problems
Best regards
Davide
VOLUMIO TECH SUPPORT
