Hello
After Update to V. 2.853, the Track Button Prev. Next doesnt work.
Anny Ideas?
Regards, azoui
Hello
Anny Ideas?
Regards, azoui
I’m having the same problem but only with tracks section
Playlists and albums seem to work
2.853
What kind of tracks are you playing? Files from USB, NAS or what ? Spotify? Tidal, QOBUZ?
Can you please send logs?
Paste the log link here
This is for Tidal, but only the track section, it was working when I upgraded to 2.853. Also in the track section it won’t play the next track continuously
Playlists and Albums seem to be working ok
Thanks your video helps!
Basically, by adding the way you do, you only add this track. Then playing next (with repeat on) it repeats the queue, with only this track.
If you just touch the track it will add all the tracks
Can you try?
Yes that worked
and it will play the next track automatically
Thank you
I liste my list from Tidal.
http://logs.volumio.org/volumio/4RP2Ktt.html
This is the output from live log:
info: CoreCommandRouter::volumioNext
info: CoreStateMachine::next
info: WARNING: No next method for plugin streaming_services
info: CoreCommandRouter::volumioPrevious
info: CoreStateMachine::previous
info: [1607357355092] ControllerTidal::seek
info: CoreStateMachine::setConsumeUpdateService mpd
info: ControllerMpd::seek
error: null
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info: ControllerMpd::pushState
info: CorePlayQueue::getTrack 156
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus play
info: Received an update from plugin. extracting info from payload
info: ------------------------------ 22ms
info: CorePlayQueue::getTrack 157
info: Prefetching next song
info: Doing prefetch in Streaming Services
Loading tidal configuration
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info: ------------------------------ 6ms
info: CoreStateMachine::startPlaybackTimer
info: ControllerMpd::next
info:
info:
info: ------------------------------ 3ms
info: ------------------------------ 27ms
