Power supply Pi 3B & 7 inch Touch Screen
Am seeking advise on what power supply requirements are recommended for Volumio with a Raspberry Pi 3B device and an official Raspberry Pi 7 inch Touch Screen.
Have been using the official 2.5A from https://www.raspberrypi.org/products/raspberry-pi-universal-power-supply/.
Unfortunately this corrupted and on posting was suggested needed a beefier power supply?
Is the official one sufficient, whether using USB to power the touch screen or using the 40 pin option?
If not what specification of power supply should I get? Suggestions on where to purchase, in Australia my local area have Altronics and Jaycar as possible places.
Thank you to the community.
I use the official power supply without any issues.
If you have a Pi 3+B (instead of the 3B), it is a different story because the 3+ has a significantly higher power consumption.
Thank you I think, need to confirm, I have the 3B+ model. Noted the slowing down when using single power supply the official Raspberry Pi 2.5A one. Have now separate power supplies to each and all seems well.
