[PLUGIN] YouTube2
Yep can confurm it is working again :slight_smile:
I can Confirm this… it is also working for me again
For me too !
After using the Clear persisted data button, it worked again!
Error. No results.
Hi, having problems with YouTube music not working. I have tried refreshing the cookies, done a factory reset on Volumio, reinstalled plugin multiple times, with no success. The most common issues are
  1. unable to access the plugin settings screen, when selected get a blured playback screen, which when I close it returns to the player screen.
  2. When selecting option from YouTube get ā€˜Error No Result’ red pop up window.
  3. Sometimes get a yellow popup window ā€˜Could not obtain i18n options’
    Thanks for any suggestions
Hi, I have managed to get the plugin working again, the way I did it was that I had Volumio UI open in one private firefox window, and then had youtube open in a separate private firefox window to get an up todate cookie. Having them in seperate windows appears to have made a difference ?.
ā€˜Error No Result’ ā€˜Could not obtain i18n options’ are also with me.
I tried using your method with separate 2 tabs private Firefox page but pluging does not work
YT is down again.
Still down
Hello
I“m following @patrickkfkan steps for having the last version of YouTube Music pluging
IĀ“m already connected to ā€œhttp://192.168.8.104/devā€. In that I can see different options, I press ā€œPlugins Test Modeā€ TRUE,
and nothing change when I restart Volumio. ā€œDetailsā€ only shows this short text
what am I missing?
There is no test mode for YouTube2 and YouTube Music plugins. Just hit the Install button to get the latest version.
Hi, where is that Button?!
If you’re referring to the YouTube Cast Receiver plugin, it’s in the plugin settings.
Sorry for my ignorance.
YouTube Music plugin reinstalled running well (Without cookie)
YouTube2 plugin reinstalled (with cookie) running well.
Thank you for your work. Thank you bro for your plugins!
It’s not working here
Like with youtube music cookie is not working any more. First error code http status 403. After reinstalling I got this error:
yt2
Been without Youtube on volumio for 2 months !!!
Rpi4 all Volumio versions last 3.802
Youtube 2 does not run with cookie
youtube2 is still not working. It is loading the content but does not play the stream. Youtubecast and youtube music also not working.
Hi all,
I set a new instance of Volumio with latest version on Raspberry Pi Zero W 2 and everything works fine except YouTube2 plugin - I have a blank settings page:
https://i.imgur.com/7ZmO2vF.png
