[PLUGIN] YouTube for Volumio
mine is like random. the search looks fine but when i select a song to play (i have to select the dots right of the song and hit play) it adds a whole list of songs of the search and starts plays a random song from this list. if you select a song from the list plays the right song. its a big issue because after adds the search on my quota so after a while reaches the limit of the api.
as i was expecting it is the version of volumio. i had an older image of my installation that i restored on an other sd card and this one works fine.
this version resolved also an other issue that i had to reconnect the spotify plugin on each reboot.
i think that i ll stay with this version.
My Volumio’s version is 2.779.
very weird 2.779 (latest) i had these issues that i told you. this one works perfectly.
@giorgosperi Which kind of version do you use now for volumio and YouTube? i have version 2.777 and 0.1.0, respectively, running on my machine. this doesnĀ“t work well, i have tried YouTube 1.0.1 but wasnĀ“t able to get it run at all so far…
and move to the next song in the middle(random) of the song.
I have version 2.779 and youtube plugin 0.1.0 20191224 with last update ytdlcore.
youtube plugin i have the same
youtube-20191224
volumio version 2.729
is there somewhere older versions of volumio? i wanted to try one by one. i have some of them downloaded
Go to ā€œ/data/plugins/music_service/youtubeā€
Then run command ā€œnpm outdatedā€.
To see if need update the dependency.
@duong_nam
let me try on my other sd card that has 2.779
volumio v2.779
Package Current Wanted Latest Location
googleapis 45.0.0 45.0.0 52.1.0 youtube
iso8601-duration 1.0.6 1.0.6 1.2.0 youtube
node-cache 5.0.1 5.0.1 5.1.1 youtube
i updated all of them out of curiosity but still the same issues.
i used also my sd card with 2.729 version
volumio v2.729
@giorgosperi
so this Version with YT 0.1.0 is working fine?
Same as me.
Goto ā€œ/data/plugins/music_service/youtube/node_modules/ytdl-coreā€
Then run ā€œnpm outdatedā€.
Mine is
html-entities 1.3.1
m3u8stream 0.7.1
miniget 1.7.2
sax 1.2.4
on volumio v2.729 and the youtube 0.1.0 that we all use with updated ytdlcore is working fine.
on volumio v2.779 the same version of youtube is doing these issues.
i wanted to find also other versions between these 2 versions to try but i have on my file 2.714 and 2.773.
html-entities MISSING 1.3.1 1.3.1 ytdl-core
m3u8stream MISSING 0.7.1 0.7.1 ytdl-core
miniget MISSING 1.7.2 2.0.0 ytdl-core
sax MISSING 1.2.4 1.2.4 ytdl-core
Should I do an update?
I think it’s ok.
20202020
mine on the latest version of volumio never worked fine.
@giorgosperi could u please provide a download of ur latest (2.729?) volumio version that works for u? I only have 2.692 on file.
Or anybody else can provide a download link, or is there a collection of older volumio versions available?
thank u very much for ur help
@domi
on file i have 2.714 2.773 and i have an image of sd card with 2.729.
i can upload probably it if you want. i was looking also an other version to download.
@giorgosperi
that would be awesome if u could manage an upload of file an Image. i would be very thankful for that :slight_smile:
@domi
i dont know if you saw this topic.
i requested and they posted some links. i have the same images i think except that i have also the 2.714
@giorgosperi
thank u so much, i haven“t seen this post before. thanks again, that helps me a lot :slight_smile:
@domi
you welcome we help each other here.
your youtube is working fine and with what version?
