After installing V2.799 the Volumio Spotify Connect2 plugin did not work anymore, Spotify does not see the device.
The first thing I did was uninstall and reinstall the plugin with no results. I repeatedly restarted both Spotify and Volumio, with no results.
I use Rasp3 + Allo Boss DAC
Could you share some logs?
Either from the /dev
page using the livelog feature or via ssh.
# Volumio logs
journalctl -f -o cat
# vollibrespot logs
journalctl -f -o cat -u volspotconnect2.service
Note you might need sudo
before these commands depending on the version of Volumio your running
Miraculously today it works normally. I didn’t change anything, just normal reboots of computers.
Any problem notice. Gracias!
