Plugin volumio-hd44780 problem
I installed volumio-hd44780-plugin. The plugin has been installed. It can be edited. The problem is that only the inscription “WELCOM to VOLUMIO 2!” Is displayed. It does not display the name of the music file being played and there is no subtitle shifting. Installation was carried out in accordance with this description.
sudo i2cdetect -y 1
wget github.com/Saiyato/volumio-hd44 … plugin.zip
mkdir volumio-hd44780-plugin
miniunzip volumio-hd44780-plugin.zip -d volumio-hd44780-plugin
cd volumio-hd44780-plugin
sudo apt-get update
sudo apt-get install apt-utils
sudo apt-get install build-essential
npm install
volumio plugin install
and later
sudo apt install python3
sudo apt install python3-pip
sudo apt install python-mpd
sudo pip3 install mpdlcd
What did I do wrong? How to solve the problem. I have the volumio-2.699-2020-01-20-pi version installed. Help
I have the same problem,
Any help is appreciated!
Thanks :pray:
Hi phtav,
Unfortunately this plugin is not supported any longer… :frowning:
I also would wish somebody with coding skills would create a plugin for HD44780
Best Regards
Josef
Thank you! My music server maybe has to change to 3.5" LCD screen
You can try with this driver.
I seriously doubt that some-one will take up development, for a single request in 3 years.
@Wheaten - We are already 2 :slight_smile: and i am sure some more would like it.
Maybe the seller of this wonderful glowing display has an idea ? I’ll ask him.
done so - he maybe will have a look into this the next weeks
@Saiyato - would you mind to get into this again and get in contact with Rafael ?
That would be supergreat for me as i would like to have VFDs working - ideally on I2C
Best Regards
Josef
driver posted 2 posts back is for rpi2-3, should work with 4.
i downloaded it, unluckily i don’t know how to use it.
Do you know of any documentation ?
