I have Roon Bridge working fine on one Pi, but on another, the plug-in is always ‘inactive’
I tried uninstalling then reinstalling the plug-in, but unstall gives this error:
“An error occurred while uninstalling the plugin: Error: Command failed: /usr/bin/sudo /bin/systemctl stop roonbridge.service Failed to stop roonbridge.service: Unit roonbridge.service not loaded.”
So the Roon service is not running. I have rebooted the Pi but same result.
Can I SSH in to remove the plug-in manually?
Or do I have to start from scratch with a new imag?
