Good afternoon. Tell me at this link https://aliexpress.ru/item/4001115081190.html Which board option should I buy A or B.
I would stay away of these exotic brands, go for wavershare + hdmi. Less troublesome to get it to work.
Is there a way to change the brightness of the display in the plug in
I have a waveshare 7.9 inch
You can do it hardware:
Backlight control
“You can control the backlight brightness by long pressing ON/OFF on the back of the LCD…”
Currently: No.
Maybe it will possible with one of the next versions of the plugin.
Please post the output of
ls -al /sys/class/backlight
and
cat /etc/modules
gvolt,
how can i do this?
sorry im new
You need to connect to Volumio via SSH. At Volumio’s command prompt type in
and hit enter. Copy the output and paste it into a new post.
Do the same the other command
cat /etc/modules
If you want to use a touch screen, buy board A. It has an interface for the touch panel, but no brightness adjustment. I have this display with board B and unfortunately I cannot buy only the touch screen but also the board. And this is a big cost. Below are two suggestions:
[70.13€ 35% OFF|Wyświetlacz Raspberry Pi Aida64 8.8 Cal 1920x480 ekran IPS wyświetlacz samochodowy Micro USB 60Hz płyta sterownicza|Ekrany LCD i panele do tabletów| - AliExpress]
Hi @gvolt
I tried to install Touch Display on new clean copy of Volumio. It looks like some error on mirror server:
Could not connect to ftp.icm.edu.pl:80 (193.219.28.2), connection timed out
Err:5 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf librsvg2-common armhf 2.44.10-2.1+rpi1+deb10u3
Unable to connect to ftp.icm.edu.pl:http:
Err:6 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf adwaita-icon-theme all 3.30.1-1
Err:11 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libatspi2.0-0 armhf 2.30.0-7
Err:12 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf at-spi2-core armhf 2.30.0-7
Err:14 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libdconf1 armhf 0.30.1-2
Err:21 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf dconf-service armhf 0.30.1-2
Err:22 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf dconf-gsettings-backend armhf 0.30.1-2
Err:23 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libgif7 armhf 5.1.4-3+deb10u1
Err:24 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libimlib2 armhf 1.5.1-1
Err:25 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf giblib1 armhf 1.2.4-12
Err:26 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libproxy1v5 armhf 0.4.15-5+deb10u1
Err:27 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf glib-networking-common all 2.58.0-2+deb10u2
Err:28 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf glib-networking-services armhf 2.58.0-2+deb10u2
Err:29 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf gsettings-desktop-schemas all 3.28.1-1
Err:30 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf glib-networking armhf 2.58.0-2+deb10u2
Err:31 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf gnome-icon-theme all 3.12.0-3
Err:32 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libatk1.0-data all 2.30.0-2
Err:33 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libatk1.0-0 armhf 2.30.0-2
Err:34 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libatk-bridge2.0-0 armhf 2.30.0-5
Err:35 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf liblcms2-2 armhf 2.9-3
Err:36 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libcolord2 armhf 1.4.3-4
Err:37 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libjson-glib-1.0-common all 1.4.4-2
Err:38 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libjson-glib-1.0-0 armhf 1.4.4-2
Err:39 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libsoup2.4-1 armhf 2.64.2-2
Err:40 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libsoup-gnome2.4-1 armhf 2.64.2-2
Err:41 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf librest-0.7-0 armhf 0.8.1-1
Err:42 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libpangoxft-1.0-0 armhf 1.42.4-8~deb10u1
Err:43 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libxcb-util0 armhf 0.3.8-3+b2
Err:44 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf libstartup-notification0 armhf 0.12-6
Err:45 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf scrot armhf 0.9-1
Err:46 Index of /pub/Linux/distributions/raspbian/raspbian buster/main armhf obsession armhf 20140608-2
Fetched 11.1 MB in 30s (364 kB/s)
Installation of openbox failed
Plugin failed to install!
Cleaning up…
I tried few times yesterday and today morning.
Here are logs:
Most often a network issue is the reason for failing downloads and changing the repository mirror as described here may help.
I thought about it and use VPN to change country but without result. Later I will try with your instruction to change mirror. Thank you.
Today I tried one more time and mirror works again.
Hi guys.
I bought this 8.8-inch 1920x480 touch display and I have problems with activating touch under Volumio. In the W10 system, touch works well, but not on Volumio 3.631. I have the latest Touch Display 3.3.8 plugin which I installed on a clean Volumio first. Then more Peppa plugins, Spotify. The display is connected to the Pi with a micro USB and mini HDMI cable and when it comes to the image itself, it is very good. The problem is that the touch screen does not work. I suspect this may be due to bad settings in the config or userconfig.txt file
At the moment I have the following settings in the config.txt file:
initramfs volumeio.initrd
gpu_mem=128
gpu_mem_256=32
gpu_mem_512=32
gpu_mem_1024=128
max_usb_current=1
[pi5]
usb_max_current_enable=1
[all]
include volumeioconfig.txt
include userconfig.txt
Volumio i2s setting below: do not alter
dtoverlay=hifiberry-dac
and these in userconfig.txt
hdmi_timings=480 0 30 30 30 1920 0 6 6 6 0 0 0 60 0 55296000 8
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
display_rotate=1
hdmi_force_mode=1
framebuffer_width=1920
framebuffer_height=480
max_framebuffer_width=1920
max_framebuffer_height=1920
I asked the seller what settings I should enter (hdmi_timings), but he replied that he didn’t know.
Can anyone help solve the problem?
Is touch not working at all on Volumio or are touch events happening at wrong places?
What Pi model are you using?
Touch doesn’t work at all on Volumio.
Neither in Touch Display nor in Volumio UI.
I use RPi 3B+.
cat /var/log/Xorg.0.log
volumio@volumio:~$
[ 76.021]
X.Org X Server 1.20.4
[ 76.022] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 76.022] Current Operating System: Linux volumio 6.1.69-v7+ #1710 SMP Thu Dec 21 13:14:13 GMT 2023 armv7l
[ 76.022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 76.023] Build Date: 04 April 2023 07:50:56AM
[ 76.023] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 76.023] Current version of pixman: 0.36.0
[ 76.024] Before reporting problems, check http://wiki.x.org
[ 76.024] Markers: (--) probed, (**) from config file, (==) default setting,
[ 76.027] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Mar 12 21:25:08 2024
[ 76.078] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 76.079] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 76.147] (==) No Layout section. Using the first Screen section.
[ 76.147] (==) No screen section available. Using defaults.
[ 76.147] (**) |-->Screen "Default Screen Section" (0)
[ 76.147] (**) | |-->Monitor "<default monitor>"
[ 76.169] (==) No monitor specified for screen "Default Screen Section".
[ 76.169] (==) Automatically adding devices
[ 76.169] (==) Automatically enabling devices
[ 76.169] (==) Automatically adding GPU devices
[ 76.169] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 76.181] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 76.181] Entry deleted from font path.
[ 76.204] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 76.204] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 76.204] (II) The server relies on udev to provide the list of input devices.
[ 76.204] (II) Loader magic: 0x1fdf80
[ 76.204] (II) Module ABI versions:
[ 76.204] X.Org ANSI C Emulation: 0.4
[ 76.204] X.Org Video Driver: 24.0
[ 76.204] X.Org XInput driver : 24.1
[ 76.204] X.Org Server Extension : 10.0
[ 76.207] (--) using VT number 2
[ 76.207] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 76.208] (II) no primary bus or device found
[ 76.208] (II) LoadModule: "glx"
[ 76.243] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 76.410] (II) Module glx: vendor="X.Org Foundation"
[ 76.410] compiled for 1.20.4, module version = 1.0.0
[ 76.410] ABI class: X.Org Server Extension, version 10.0
[ 76.410] (==) Matched modesetting as autoconfigured driver 0
[ 76.410] (==) Matched fbdev as autoconfigured driver 1
[ 76.410] (==) Assigned the driver to the xf86ConfigLayout
[ 76.410] (II) LoadModule: "modesetting"
[ 76.411] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 76.434] (II) Module modesetting: vendor="X.Org Foundation"
[ 76.435] compiled for 1.20.4, module version = 1.20.4
[ 76.435] Module class: X.Org Video Driver
[ 76.435] ABI class: X.Org Video Driver, version 24.0
[ 76.435] (II) LoadModule: "fbdev"
[ 76.435] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 76.454] (II) Module fbdev: vendor="X.Org Foundation"
[ 76.454] compiled for 1.20.3, module version = 0.5.0
[ 76.454] Module class: X.Org Video Driver
[ 76.454] ABI class: X.Org Video Driver, version 24.0
[ 76.454] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 76.454] (II) FBDEV: driver for framebuffer: fbdev
[ 76.477] (WW) Falling back to old probe method for modesetting
[ 76.478] (EE) open /dev/dri/card0: No such file or directory
[ 76.478] (WW) Falling back to old probe method for fbdev
[ 76.478] (II) Loading sub module "fbdevhw"
[ 76.478] (II) LoadModule: "fbdevhw"
[ 76.478] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 76.497] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 76.498] compiled for 1.20.4, module version = 0.0.2
[ 76.498] ABI class: X.Org Video Driver, version 24.0
[ 76.498] (II) FBDEV(0): using default device
[ 76.498] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 76.498] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 76.498] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 76.498] (==) FBDEV(0): RGB weight 888
[ 76.498] (==) FBDEV(0): Default visual is TrueColor
[ 76.499] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 76.499] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 3600kB)
[ 76.499] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 76.499] (II) FBDEV(0): checking modes against framebuffer device...
[ 76.499] (II) FBDEV(0): checking modes against monitor...
[ 76.499] (II) FBDEV(0): Virtual size is 1920x480 (pitch 1920)
[ 76.499] (**) FBDEV(0): Built-in mode "current"
[ 76.499] (==) FBDEV(0): DPI set to (96, 96)
[ 76.499] (II) Loading sub module "fb"
[ 76.499] (II) LoadModule: "fb"
[ 76.499] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 76.514] (II) Module fb: vendor="X.Org Foundation"
[ 76.515] compiled for 1.20.4, module version = 1.0.0
[ 76.515] ABI class: X.Org ANSI C Emulation, version 0.4
[ 76.515] (**) FBDEV(0): using shadow framebuffer
[ 76.515] (II) Loading sub module "shadow"
[ 76.515] (II) LoadModule: "shadow"
[ 76.515] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 76.530] (II) Module shadow: vendor="X.Org Foundation"
[ 76.531] compiled for 1.20.4, module version = 1.1.0
[ 76.531] ABI class: X.Org ANSI C Emulation, version 0.4
[ 76.531] (II) UnloadModule: "modesetting"
[ 76.531] (II) Unloading modesetting
[ 76.578] (==) FBDEV(0): Backing store enabled
[ 76.589] (==) FBDEV(0): DPMS enabled
[ 76.593] (II) Initializing extension Generic Event Extension
[ 76.595] (II) Initializing extension SHAPE
[ 76.596] (II) Initializing extension MIT-SHM
[ 76.597] (II) Initializing extension XInputExtension
[ 76.603] (II) Initializing extension XTEST
[ 76.604] (II) Initializing extension BIG-REQUESTS
[ 76.605] (II) Initializing extension SYNC
[ 76.606] (II) Initializing extension XKEYBOARD
[ 76.607] (II) Initializing extension XC-MISC
[ 76.608] (II) Initializing extension SECURITY
[ 76.609] (II) Initializing extension XFIXES
[ 76.611] (II) Initializing extension RENDER
[ 76.612] (II) Initializing extension RANDR
[ 76.614] (II) Initializing extension COMPOSITE
[ 76.618] (II) Initializing extension DAMAGE
[ 76.620] (II) Initializing extension MIT-SCREEN-SAVER
[ 76.622] (II) Initializing extension DOUBLE-BUFFER
[ 76.623] (II) Initializing extension RECORD
[ 76.625] (II) Initializing extension DPMS
[ 76.638] (II) Initializing extension Present
[ 76.639] (II) Initializing extension DRI3
[ 76.639] (II) Initializing extension X-Resource
[ 76.641] (II) Initializing extension XVideo
[ 76.642] (II) Initializing extension XVideo-MotionCompensation
[ 76.642] (II) Initializing extension SELinux
[ 76.642] (II) SELinux: Disabled on system
[ 76.642] (II) Initializing extension GLX
[ 76.643] (II) AIGLX: Screen 0 is not DRI2 capable
[ 78.490] (II) IGLX: Loaded and initialized swrast
[ 78.490] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 78.490] (II) Initializing extension XFree86-VidModeExtension
[ 78.491] (II) Initializing extension XFree86-DGA
[ 78.492] (II) Initializing extension XFree86-DRI
[ 78.497] (II) Initializing extension DRI2
[ 78.849] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event0)
[ 78.849] (**) USB OPTICAL MOUSE: Applying InputClass "libinput pointer catchall"
[ 78.849] (II) LoadModule: "libinput"
[ 78.850] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 78.901] (II) Module libinput: vendor="X.Org Foundation"
[ 78.901] compiled for 1.20.3, module version = 0.28.2
[ 78.901] Module class: X.Org XInput Driver
[ 78.901] ABI class: X.Org XInput driver, version 24.1
[ 78.901] (II) Using input driver 'libinput' for ' USB OPTICAL MOUSE'
[ 78.901] (**) USB OPTICAL MOUSE: always reports core events
[ 78.901] (**) Option "Device" "/dev/input/event0"
[ 78.901] (**) Option "_source" "server/udev"
[ 78.937] (II) event0 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[ 78.937] (II) event0 - USB OPTICAL MOUSE: device is a pointer
[ 78.938] (II) event0 - USB OPTICAL MOUSE: device removed
[ 79.000] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/0003:0000:0538.0001/input/input0/event0"
[ 79.000] (II) XINPUT: Adding extended input device " USB OPTICAL MOUSE" (type: MOUSE, id 6)
[ 79.001] (**) Option "AccelerationScheme" "none"
[ 79.001] (**) USB OPTICAL MOUSE: (accel) selected scheme none/0
[ 79.001] (**) USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 79.001] (**) USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 79.010] (II) event0 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[ 79.010] (II) event0 - USB OPTICAL MOUSE: device is a pointer
[ 79.015] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 79.015] (II) No input driver specified, ignoring this device.
[ 79.015] (II) This device may have been added with another device file.
volumio@volumio:~$
Please try if running
sudo apt-get -y install xserver-xorg-input-evdev
sudo cp /usr/share/X11/xorg.conf.d/10-evdev.conf /etc/X11/xorg.conf.d/45-evdev.conf
and restarting the Touch Display plugin helps.
I entered both commands. After that, I restarted the plugin.
After restarting the Touch Display plugin there was no improvement.
After restarting the entire system, I now have a black screen in Volumio, but the player can be launched from the laptop. The screen with Peppa and Now Playing simply disappeared.
Please again post the result of
Also report what’s the effect of removing “/etc/X11/xorg.conf.d/45-evdev.conf” by executing
sudo rm /etc/X11/xorg.conf.d/45-evdev.conf
and rebooting Volumio?
