Hello all,
I recently buy the official 7" touch screen from raspberry pi.
I have installed the plugin, working fine but I have some problem since I have changed the orientation of the screen to 270°.
The screen is rotated but the mouse is not (still to 0°). But sometimes it works, sometimes not… But at each first boot it is not working.
Any suggestion ? Any bug report to do ?
Many thanks in advance
Regards
Benoit
No bug report required. I’m already investigating the issue that touch rotation does not always get applied properly.
Thank you very much ! If you need some help to test with my setup do not hesitate.
Thanks again
Benoit
