This appears to be irrelevant. What’s important is when playback switches to another song, does #pushState()...
appear in the logs with the corresponding song info?
#pushState() NOT appear in the logs with the corresponding song info.
If not the corresponding song info, then what info does #pushState()
appear with?
Nothing.
It works with albums but not with radio.
I could not reproduce the issue with the radio stations I’ve tested. On the other hand, I could not find Radio France under the Radio section. Do you have issues with the other radio stations? E.g. Radio → Music → Top 40 & Pop Music → Stations → SLAM! Non Stop (Netherlands)
Thanks for your help but I have install picoplayer and everything works well.
I have a Raspberry Pi 4B and I’m getting the same error that @MikeyFresh was in the web interface. If I SSH into Volumio and manually start squeezelite via /opt/squeezelite/squeezelite
then it does show up in my LMS as a player. Also, if I stop squeezelite in the SSH connection, then in the web interface I see a message saying that connection to LMS was lost. Any ideas?
was this issue ever solved? Unfortunately, i am experiencing the same behaviour (i can play songs and listen to them but no controlling or monitoring possible via Volumio GUI). It would be great to have some solutions for that.
Greetings and thanks for your work.
