@Maegashira, @audiofan Thank you and let me know if you see room for improvement (within my abilities
How can I install plug-in for soundcloud or mixcloud into my Volumio Primo hifi edition, I donāt have practice, and I need something easy. thanks at all.
enable ssh
your_ip/dev or volumio.local if you didnāt change te name
if you got putty ssh in to your device again your_ip and login and password both are : volumio
after that go to the page of soundcloud
go to Getting Started follow the step there this should install the plugin and the same for mixcloud or youtube2
Iām going to get putty ssh, following your steps
if you need some help just say so
I hope itās easy
I just installed putty 64 bit, and after that?
do you know your ip of your primo?
I try to remember
most of the time itās 192.168.1.xxx you can find it under settings >> network
thanks, find it
Iām into soundcloud (already have an account) but i donāt see Getting Started
this is only the free part of soundcloud so there is no login⦠same with mixcloud
and youtube2 (can use api login with google account ) or you can use scraping
but you can use the top search box to find whatās there
ok, but I put my IP volumio into box serching and I do enable to SSH box, are you sure any damage could be to volumio?
oke recap all the steps you did⦠this sounds like mixed infoā¦
1 in a browser use your_ip/dev or volumio.local/dev
2. enable ssh in your_ip/dev
3. go in to putty use your_ip as hostename and save it
4. press open
5. you get a screen of putty with
login: volumio ( press enter)
password: volumio ( press enter)
6. now follow the steps of soundCloud instructions Getting Started:
paste this and press enter :
mkdir soundcloud-plugin -
cd soundcloud-plugin -
paste this and press enter wait till it finishes:
git clone https://github.com/patrickkfkan/volumio-soundcloud.git -
cd volumio-soundcloud -
paste this and press enter wait till you see Progress: 100,Status :SoundCloud Successfully Installed
volumio plugin install -
enable sound cloud under plugins
Iām to point 6, where can I find follwing steps of soundcloud?
no you first have to install the pluginā¦
after that enable the pluginā¦
sorry i donāt understand, I just have to enable soundcloud plugins?
