fixed two typos and submitted again - you need to reinstall (left the version on 1.0.18). I installed fusion and tested on my test-system and can see the button in the Fusion settings toggle now.
I’m a bit reluctant to implement reading the config file of the Fusion plugin and monitor for changes - more effort and needs some care to not get into any undesired state - so I leave it as is for the moment. Probably, this toggling is not something, that you do several times in a listening session, so it probably is only a minor annoyance, if you have to press the button twice
Hi
Did you upload the fixed version ? I uninstalled/reinstalled and I am getting exactly the same outcome.
I restored a backup of my system and updated your plugin from that, same result.
So not sure if the older version of .18 is cached somewhere else.
Thanks for your time.
Mmmmh - I was certain I could “re-submit” versions with the same number, but that seems to fail now. Nevermind, I increased the version to 1.0.19 and that is available on the beta-channel now. Did not install it from there, but I think it should work. sorry for the inconvenience…
Had a good play around with it today.
It works pretty well in Volumio 3.251 turning the “effects” on and off almost perfectlty, sometimes on first press I have to press twice like you say. (Toggle not in sync ?)
But…in the latest version 3.429 (also 3.378) I cannot get it to function at all, It also stops the effects on/off button in the quick menu (in manifest layout) working properly.
Thanks for checkin. My system is on 3.396, as far as I know and it worked. Will see if I can update it and check over the weekend.
If you can generate a log, that would help.
However, if it also stops the button in the settings from working, I suspect it is not the rotaryencoder plugin.
I basically send either an activateeffects or a deactivateeffect command to the Fusion plugin via the websocket interface. Would not see, how that could deactivate the button in the interface.
But let‘s see…
The Button to enable and disable effects actually in the settings for the fusion plugin still works.
Once you set the rotary encoder II button and try to use it, that doesnt work and also the button in the quick menu in manifest stops working properly as well. pic
Hope that make sense.
Ive still got 3.378 on another SD card, I’ll load it up and generate a log when I get a few mins.
Degug on and a copy of the live log. Is that OK ?
That should give us an idea. Will see when I find time to start up my test-system again.
Hi
I have just loaded up 3.378 on another card and cannot for the life of me reproduce what was happening all yesterday afternoon. It just works. The quick menu effects button occasionally stops but the push button continues to work without issue, so like you say probably not a RE2 problem.
Maybe a dodgey SDCard or more than likely was an error between keyboard and chair.
I’ll try 3.429 again at some point see what happens.
Thanks again for enabling this function, its a usefull addition.
Good to hear! Let me know how it goes.
I’ll then work on some other projects on the weekend and not further look into it for the moment.
I am new with Volumio. I installed Rotary Encoder II plugin , set all function and save. It work. But after some time plugin was inactive status. I checked it and i cannot change anything. Even unistall dos nor work. when i change anything and press save button then nothig happen. Volumio is 3.429 version and plugin is 1.0.15
Could you advice what i can check?
Hi!
Can you try to generate a log-file? It is explained in the first post in this thread.
Just to let you know, I did get around to doing a fresh install of Volumio 3.429 with REII 1.0.19 on a new SDCard.
This time all works fine and am unable to replicate the problems I was getting before. It seems very stable. Using the button to turn the EQ on and off quite a few times during a ~4 hour session last night with no issues at all.
Part of the problem that RobgiE is having ie… not being able to save settings or uninstall was one of the symptoms I was getting when it stopped working and the only way out of that was to delete /data/configuration/system_hardware/rotaryencoder2/config.json , reboot and renter all the settings.
I try to do log but i am not sue if something shoud appear (new window) because nothing change when i choose log on or off. i did it by browser.
Do you mean, that you see nothing in the log under http://volumio.local/dev?
It should work as shown in this screenshot
If that works, it would help me to see what happens, when you try to enable/disable the plug-in and try to save settings. It does not matter in the first step, if logging in the plug-in is enabled, Volumio does some logging by default already, which might give a hint, why it seems not to work for you.
Sorry for late answer. I did it wrong before.
Finally i enable log.
Starting Live Log...
info: touch_display: Setting screensaver timeout to 30 seconds.
info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
info: CorePlayQueue::getTrack 2
info: Listing playlists
info: Enabling plugin rotaryencoder2
info: Loading plugin "rotaryencoder2"...
info: PLUGIN START: rotaryencoder2
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay rotary-encoder pin_a=23 pin_b=24 relative_axis=true steps-per-period=2
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
info: CALLMETHOD: system_controller my_volumio retreiveBackendEventStates undefined
info: CoreCommandRouter::executeOnPlugin: my_volumio , retreiveBackendEventStates
info: Received Get System Version
info: CALLMETHOD: system_hardware rotaryencoder2 updateEncoder [object Object]
info: CoreCommandRouter::executeOnPlugin: rotaryencoder2 , updateEncoder
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -l
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -r 0
error: [ROTARYENCODER2] addEventHandle: stderr: /bin/cat: /dev/input/by-path/platform-rotary@17-event
error: [ROTARYENCODER2] addEventHandle: stderr: : No such device
error: [ROTARYENCODER2] detachListener: could not kill handler process [object Object]
process exited with code null
Thanks, much better. The problem seems to be somewhere at the level, where the plug-in interacts with the kernel driver for the rotary.
Are you familiar with SSH?
We need to find out, why the plug-in is not able to properly install the dt-overlays.
I already wrote step-by-step instructions. The only thing you need is SSH.
If you use a Mac or Linux machine, it is included with the OS. On Windows you may need to install a client like PuTTY.
You can find the diagnosis instructions here.
Mar 16 17:54:13 volumio systemd[2644]: mpd.service: Failed with result 'exit-cod e'.
Mar 16 17:54:13 volumio systemd[2644]: Failed to start Music Player Daemon.
Mar 16 17:54:13 volumio systemd[2644]: Reached target Default.
Mar 16 17:54:13 volumio systemd[2644]: Startup finished in 1.841s.
Mar 16 17:54:20 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:54:20 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:54:20 volumio volumio[863]: info: Listing playlists
Mar 16 17:54:30 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:54:30 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:54:40 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:54:40 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:54:40 volumio volumio[863]: info: Listing playlists
Mar 16 17:54:50 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:54:50 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:00 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:00 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:00 volumio volumio[863]: info: Listing playlists
Mar 16 17:55:10 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:10 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:20 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:20 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:20 volumio volumio[863]: info: Listing playlists
Mar 16 17:55:24 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:55:24 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
Mar 16 17:55:30 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:30 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:31 volumio volumio[863]: info: Enabling plugin rotaryencoder2
Mar 16 17:55:31 volumio volumio[863]: info: Loading plugin "rotaryencoder2"...
Mar 16 17:55:31 volumio volumio[863]: info: PLUGIN START: rotaryencoder2
Mar 16 17:55:32 volumio volumio[863]: verbose: New Socket.io Connection to local host:3000 from 127.0.0.1 UA: node-XMLHttpRequest Total Clients: 14
Mar 16 17:55:32 volumio sudo[2852]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay rotary-encoder pin_a=23 pin_b=24 relative_axis=true steps-per-period=2
Mar 16 17:55:32 volumio sudo[2852]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:32 volumio kernel: rotary-encoder rotary@17: gray
Mar 16 17:55:32 volumio kernel: input: rotary@17 as /devices/platform/rotary@17/ input/input3
Mar 16 17:55:32 volumio sudo[2852]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:32 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:32 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:32 volumio systemd-udevd[2863]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Mar 16 17:55:32 volumio volumio[863]: info: Enabling plugin rotaryencoder2
Mar 16 17:55:32 volumio volumio[863]: info: Loading plugin "rotaryencoder2"...
Mar 16 17:55:32 volumio volumio[863]: info: PLUGIN START: rotaryencoder2
Mar 16 17:55:32 volumio volumio[863]: verbose: New Socket.io Connection to local host:3000 from 127.0.0.1 UA: node-XMLHttpRequest Total Clients: 15
Mar 16 17:55:32 volumio sudo[2869]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay rotary-encoder pin_a=23 pin_b=24 relative_axis=true steps-per-period=2
Mar 16 17:55:32 volumio sudo[2869]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:32 volumio sudo[2869]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:40 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:40 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:40 volumio volumio[863]: info: Listing playlists
Mar 16 17:55:42 volumio sudo[2904]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Mar 16 17:55:42 volumio sudo[2904]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:42 volumio sudo[2904]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:42 volumio sudo[2906]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 16 17:55:42 volumio sudo[2906]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:42 volumio sudo[2906]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:43 volumio volumio[863]: verbose: New Socket.io Connection to 192.1 68.100.119 from 192.168.100.3 UA: Mozilla/5.0 (Windows NT 10.0; Win64; x64) Appl eWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36 Total Clients: 15
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: appearance , isLatestTOSAccepted
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::volumioGetVisible Sources
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:43 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Mar 16 17:55:43 volumio volumio[863]: info: Received Get System Info
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:55:43 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:55:43 volumio volumio[863]: info: Listing playlists
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Mar 16 17:55:43 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Mar 16 17:55:44 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
Mar 16 17:55:44 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:55:44 volumio volumio[863]: info: Received Get System Info
Mar 16 17:55:44 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:55:44 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:55:44 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:55:44 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:44 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:44 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:55:46 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:55:46 volumio volumio[863]: info: Received Get System Info
Mar 16 17:55:46 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:55:46 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:55:46 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:55:46 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:46 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:46 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:55:49 volumio volumio[863]: info: CoreCommandRouter::getUIConfigOnPlug in
Mar 16 17:55:50 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:50 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:53 volumio volumio[863]: info: CALLMETHOD: system_hardware rotaryen coder2 updateEncoder [object Object]
Mar 16 17:55:53 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: rotaryencoder2 , updateEncoder
Mar 16 17:55:54 volumio sudo[2933]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -l
Mar 16 17:55:54 volumio sudo[2933]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:54 volumio sudo[2933]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:54 volumio sudo[2938]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -r 0
Mar 16 17:55:54 volumio sudo[2938]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:54 volumio volumio[863]: error: [ROTARYENCODER2] addEventHandle: st derr: /bin/cat: /dev/input/by-path/platform-rotary@17-event
Mar 16 17:55:54 volumio volumio[863]: error: [ROTARYENCODER2] addEventHandle: st derr: : No such device
Mar 16 17:55:54 volumio sudo[2938]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:54 volumio sudo[2948]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -l
Mar 16 17:55:54 volumio sudo[2948]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:54 volumio sudo[2948]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:57 volumio sudo[2955]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Mar 16 17:55:57 volumio sudo[2957]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 16 17:55:57 volumio sudo[2955]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:57 volumio sudo[2957]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:55:57 volumio sudo[2955]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:57 volumio sudo[2957]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:55:57 volumio volumio[863]: verbose: New Socket.io Connection to 192.1 68.100.119 from 192.168.100.3 UA: Mozilla/5.0 (Windows NT 10.0; Win64; x64) Appl eWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36 Total Clients: 15
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: appearance , isLatestTOSAccepted
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::volumioGetVisible Sources
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::getUIConfigOnPlug in
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:57 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Mar 16 17:55:57 volumio volumio[863]: info: Received Get System Info
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:55:57 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:55:57 volumio volumio[863]: info: Listing playlists
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Mar 16 17:55:57 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
Mar 16 17:55:58 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:55:58 volumio volumio[863]: info: Received Get System Info
Mar 16 17:55:58 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:55:58 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:55:58 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:55:58 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:58 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:58 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:55:59 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:55:59 volumio volumio[863]: info: Received Get System Info
Mar 16 17:55:59 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:55:59 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:55:59 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:55:59 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:55:59 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:55:59 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:56:00 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:00 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:56:00 volumio volumio[863]: info: Listing playlists
Mar 16 17:56:08 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:56:08 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:08 volumio volumio[863]: info: Prefetching next song
Mar 16 17:56:08 volumio volumio[863]: info: DOING PREFETCH IN MPD
Mar 16 17:56:08 volumio volumio[863]: verbose: ControllerMpd::sendMpdCommand add "USB/MuzykaPi/FLAC/Alan Walker - Different World (2018) [FLAC]/12. Alan Walker - Alone.flac"
Mar 16 17:56:08 volumio volumio[863]: ---------------------------- MPD announces system playlist update
Mar 16 17:56:08 volumio volumio[863]: info: Ignoring MPD Status Update
Mar 16 17:56:08 volumio volumio[863]: info: sendMpdCommand add "USB/MuzykaPi/FLA C/Alan Walker - Different World (2018) [FLAC]/12. Alan Walker - Alone.flac" took 5 milliseconds
Mar 16 17:56:08 volumio volumio[863]: verbose: ControllerMpd::sendMpdCommand con sume 1
Mar 16 17:56:08 volumio volumio[863]: info: ------------------------------ 5ms
Mar 16 17:56:08 volumio volumio[863]: info: sendMpdCommand consume 1 took 3 mill iseconds
Mar 16 17:56:10 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:10 volumio volumio[863]: info: CorePlayQueue::getTrack 6
Mar 16 17:56:12 volumio volumio[863]: info: CALLMETHOD: system_hardware rotaryen coder2 updateEncoder [object Object]
Mar 16 17:56:12 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: rotaryencoder2 , updateEncoder
Mar 16 17:56:12 volumio volumio[863]: error: [ROTARYENCODER2] detachListener: co uld not kill handler process [object Object]
Mar 16 17:56:12 volumio volumio[863]: info: CoreStateMachine::startPlaybackTimer
Mar 16 17:56:12 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:13 volumio volumio[863]: info:
Mar 16 17:56:13 volumio volumio[863]: ---------------------------- MPD announces system playlist update
Mar 16 17:56:13 volumio volumio[863]: info: Ignoring MPD Status Update
Mar 16 17:56:13 volumio volumio[863]: ---------------------------- MPD announces state update: player
Mar 16 17:56:13 volumio volumio[863]: info: ControllerMpd::getState
Mar 16 17:56:13 volumio volumio[863]: verbose: ControllerMpd::sendMpdCommand sta tus
Mar 16 17:56:13 volumio volumio[863]: info: ------------------------------ 9ms
Mar 16 17:56:13 volumio volumio[863]: info: sendMpdCommand status took 2 millise conds
Mar 16 17:56:13 volumio volumio[863]: verbose: ControllerMpd::parseState
Mar 16 17:56:13 volumio volumio[863]: verbose: ControllerMpd::sendMpdCommand pla ylistinfo
Mar 16 17:56:13 volumio volumio[863]: info: sendMpdCommand playlistinfo took 6 m illiseconds
Mar 16 17:56:13 volumio volumio[863]: verbose: ControllerMpd::parseTrackInfo
Mar 16 17:56:13 volumio volumio[863]: info: ControllerMpd::pushState
Mar 16 17:56:13 volumio volumio[863]: info: CoreCommandRouter::servicePushState
Mar 16 17:56:13 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:13 volumio volumio[863]: verbose: STATE SERVICE {"status":"play","p osition":0,"seek":45,"duration":160,"samplerate":"44.1 kHz","bitdepth":"16 bit", "channels":2,"random":false,"updatedb":false,"repeat":false,"bitrate":"1414 Kbps ","isStreaming":false,"title":"Alone","artist":"Alan Walker","album":"Different World","uri":"USB/MuzykaPi/FLAC/Alan Walker - Different World (2018) [FLAC]/12. Alan Walker - Alone.flac","trackType":"flac"}
Mar 16 17:56:13 volumio volumio[863]: verbose: CURRENT POSITION 11
Mar 16 17:56:13 volumio volumio[863]: info: CoreStateMachine::syncState stateS ervice play
Mar 16 17:56:13 volumio volumio[863]: info: CoreStateMachine::syncState curren tStatus play
Mar 16 17:56:13 volumio volumio[863]: info: Received an update from plugin. extr acting info from payload
Mar 16 17:56:13 volumio volumio[863]: info: CoreStateMachine::pushState
Mar 16 17:56:13 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Mar 16 17:56:13 volumio volumio[863]: info: CoreCommandRouter::volumioPushState
Mar 16 17:56:13 volumio volumio[863]: info: ------------------------------ 155ms
Mar 16 17:56:13 volumio volumio[863]: info: [GPIO_Control] *** musicPlay ***
Mar 16 17:56:13 volumio volumio[863]: info: [GPIO_Control] Delaying: 0ms
Mar 16 17:56:13 volumio volumio[863]: info: [GPIO_Control] Turning GPIO 6 On (mu sicPlay)
Mar 16 17:56:14 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Mar 16 17:56:14 volumio volumio[863]: info: CALLMETHOD: system_controller my_vol umio retreiveBackendEventStates undefined
Mar 16 17:56:14 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , retreiveBackendEventStates
Mar 16 17:56:14 volumio volumio[863]: info: Received Get System Version
Mar 16 17:56:14 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Mar 16 17:56:20 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:20 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:20 volumio volumio[863]: info: Listing playlists
Mar 16 17:56:22 volumio sudo[3018]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Mar 16 17:56:22 volumio sudo[3020]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 16 17:56:22 volumio sudo[3020]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:56:22 volumio sudo[3018]: pam_unix(sudo:session): session opened for u ser root by (uid=0)
Mar 16 17:56:22 volumio sudo[3020]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:56:22 volumio sudo[3018]: pam_unix(sudo:session): session closed for u ser root
Mar 16 17:56:22 volumio volumio[863]: verbose: New Socket.io Connection to 192.1 68.100.119 from 192.168.100.3 UA: Mozilla/5.0 (Windows NT 10.0; Win64; x64) Appl eWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36 Total Clients: 15
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: appearance , isLatestTOSAccepted
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::volumioGetVisible Sources
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::getUIConfigOnPlug in
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:22 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Mar 16 17:56:22 volumio volumio[863]: info: Received Get System Info
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:56:22 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:56:22 volumio volumio[863]: info: Listing playlists
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Mar 16 17:56:22 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
Mar 16 17:56:23 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:56:23 volumio volumio[863]: info: Received Get System Info
Mar 16 17:56:23 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:56:23 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:56:23 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:56:23 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:23 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:23 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:56:24 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 16 17:56:24 volumio volumio[863]: info: Received Get System Info
Mar 16 17:56:24 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: system , getSystemInfo
Mar 16 17:56:24 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , getThisDevice
Mar 16 17:56:24 volumio volumio[863]: info: Discovery: Getting this device infor mation
Mar 16 17:56:24 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:24 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Mar 16 17:56:24 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin: network , getCachedIPAddresses
Mar 16 17:56:30 volumio volumio[863]: info: CoreCommandRouter::volumioGetState
Mar 16 17:56:30 volumio volumio[863]: info: CorePlayQueue::getTrack 11
Your formatting is pretty messed up, but after straightening it out, I cannot really see the root cause.
What I can see:
- The plugin gets started and tries to install the overlay
- For some strange reason, the plugin gets started again, without being stopped intermediately (why??? I have no idea). Or did you copy the same sections twice, accidentally? There is no kernel message after this call, so there probably is something wrong.
- Then it seems, that you try to save a setting from the UI. Normally, that causes the plugin to uninstall all rotaries first and then reinstall them with the new settings. But uninstalling them already fails.
- Then there is another error message informing us, that the listener also could not be removed
I explain the log below.
I cannot really make a guess right now, but I have no system on 3.429 at the moment. Since I do not want to mess up my development system, I have to see when I find time to setup a fresh SD card and try that version.
In the meantime you could try to install the last beta of the plugin from the beta-channel (1.0.18). It might be, that I fixed something causing this in the meantime (although unlikely).
What system are you on and do you have other plugins or hardware installed?
Your log with comments (I removed the parts, that are irrelevant):
;########### HERE THE PLUGIN GETS STARTED AND THE OVERLAY IS INSTALLED SUCCESSFULLY
Mar 16 17:55:32 volumio sudo[2852]: volumio : TTY=unknown ; PWD=/ ; USER=root ;COMMAND=/usr/bin/dtoverlay rotary-encoder pin_a=23 pin_b=24 relative_axis=true steps-per-period=2
Mar 16 17:55:32 volumio kernel: input: rotary@17 as /devices/platform/rotary@17/input/input3
Mar 16 17:55:32 volumio sudo[2852]: pam_unix(sudo:session): session closed for user root
;########### HERE THE PLUGIN GETS STARTED AGAIN WITHOUT INTERMEDIATE STOP (???) AND THE OVERLAY IS INSTALLED AGAIN BUT THIS TIME, THERE IS NO KERNEL RESPONSE
;########### THE TIMESTAMP IS THE SAME AS ABOVE, COULD THIS BE A DUPLICATE
Mar 16 17:55:32 volumio volumio[863]: verbose: New Socket.io Connection to localhost:3000 from 127.0.0.1 UA: node-XMLHttpRequest Total Clients: 15
Mar 16 17:55:32 volumio sudo[2869]: volumio : TTY=unknown ; PWD=/ ; USER=root ;COMMAND=/usr/bin/dtoverlay rotary-encoder pin_a=23 pin_b=24 relative_axis=true steps-per-period=2
;########### THE CONFIGURATION GETS CHANGED FROM THE UI AND BECAUSE THE ROTARY IS INSTALLED, IT FIRST HAS TO BE REMOVED. BUT IT IS NOT THERE, THEREFORE WE GET AN ERROR
Mar 16 17:55:53 volumio volumio[863]: info: CALLMETHOD: system_hardware rotaryencoder2 updateEncoder [object Object]
Mar 16 17:55:53 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin:rotaryencoder2 , updateEncoder
Mar 16 17:55:54 volumio sudo[2933]: volumio : TTY=unknown ; PWD=/ ; USER=root ;COMMAND=/usr/bin/dtoverlay -l
Mar 16 17:55:54 volumio sudo[2933]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 16 17:55:54 volumio sudo[2933]: pam_unix(sudo:session): session closed for user root
Mar 16 17:55:54 volumio sudo[2938]: volumio : TTY=unknown ; PWD=/ ; USER=root ;COMMAND=/usr/bin/dtoverlay -r 0
Mar 16 17:55:54 volumio sudo[2938]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 16 17:55:54 volumio volumio[863]: error: [ROTARYENCODER2] addEventHandle: stderr: /bin/cat: /dev/input/by-path/platform-rotary@17-event
Mar 16 17:55:54 volumio volumio[863]: error: [ROTARYENCODER2] addEventHandle: stderr: : No such device
Mar 16 17:55:54 volumio sudo[2938]: pam_unix(sudo:session): session closed for user root
Mar 16 17:55:54 volumio sudo[2948]: volumio : TTY=unknown ; PWD=/ ; USER=root ;COMMAND=/usr/bin/dtoverlay -l
;########### FOR THE SAME REASON, THE LISTENER CANNOT BE REMOVED
Mar 16 17:56:12 volumio volumio[863]: info: CALLMETHOD: system_hardware rotaryencoder2 updateEncoder [object Object]
Mar 16 17:56:12 volumio volumio[863]: info: CoreCommandRouter::executeOnPlugin:rotaryencoder2 , updateEncoder
Mar 16 17:56:12 volumio volumio[863]: error: [ROTARYENCODER2] detachListener: could not kill handler process [object Object]
Update: I have upgraded to Volumio 3.435 and on my end the plugin is still working like usual.
I noticed another thing:
In your log, there are only error messages from the plugin (error: [ROTARYENCODER2]) but no processing information. Can you do me a favor and first enable the logging at the very bottom of the plugin settings and after that generate a new log, where I can see how you enable the plugin? This way we may be able to see exactly where it starts to fail.
I have made a video demonstrating, how to make a log via the browser.
