Those are actually only a few lines of code. It works flawless on my Volumio machine already.
If you feel comfortable with SSH, you can already test it by replacing the content of the file
/data/plugins/miscellanea/lastfm/index.js
with this:
[code]‘use strict’;
var libQ = require(‘kew’);
var libNet = require(‘net’);
var fs = require(‘fs-extra’);
var config = new (require(‘v-conf’))();
var exec = require(‘child_process’).exec;
var net = require(‘net’);
var os = require(‘os’);
var currentMac = ‘’;
var pTimer = require(‘./pausableTimer’);
var io = require(‘socket.io-client’);
var socket = io.connect(‘http://localhost:3000’);
var lastfm = require(“simple-lastfm”);
var crypto = require(‘crypto’);
// Define the ControllerLastFM class
module.exports = ControllerLastFM;
function ControllerLastFM(context)
var self = this;
self.previousState = null;
self.updatingNowPlaying = false;
self.playTime = 0;
this.context = context;
this.commandRouter = this.context.coreCommand;
this.logger = this.context.logger;
this.configManager = this.context.configManager;
this.previousScrobble =
{ artist: '',
title: '',
scrobbleTime: 0
this.memoryTimer;
ControllerLastFM.prototype.onVolumioStart = function()
var self = this;
var initialize = false;
this.configFile = this.commandRouter.pluginManager.getConfigurationFile(this.context, ‘config.json’);
self.getConf(this.configFile);
self.logger.info('[LastFM] scrobbler initiated!');
self.logger.info('[LastFM] extended logging: ' + self.config.get('enable_debug_logging'));
self.logger.info('[LastFM] try scrobble radio plays: ' + self.config.get('tryScrobbleWebradio'));
self.currentTimer = new pTimer(self.context, self.config.get('enable_debug_logging'));
socket.on('pushState', function (state) {
if(!self.currentTimer)
if(self.config.get('enable_debug_logging'))
self.logger.info('[LastFM] created new timer object');
else
self.logger.info('[LastFM] timer should be there... using the existing instance');
var scrobbleThresholdInMilliseconds = 0;
if(state.service == 'mpd' || state.service == 'airplay' || state.service == 'volspotconnect2' || state.service == 'radio_paradise')
scrobbleThresholdInMilliseconds = state.duration * (self.config.get('scrobbleThreshold') / 100) * 1000;
else if (state.service == 'webradio')
scrobbleThresholdInMilliseconds = self.config.get('webradioScrobbleThreshold') * 1000;
var previousTitle = 'null';
if(self.previousState != null && self.previousState.title != null)
previousTitle = self.previousState.title;
// Set initial previousState object
var init = '';
if(self.previousState == null)
self.logger.info('[LastFM] initializing previous state object.');
self.previousState = state;
initialize = true;
init = ' | Initializing: true';
self.logger.info('--------------------------------------------------------------------// [LastFM] new state has been pushed; status: ' + state.status + ' | service: ' + state.service + ' | duration: ' + state.duration + ' | title: ' + state.title + ' | previous title: ' + previousTitle + init);
if (state.status == 'play' && (state.service == 'mpd' || state.service == 'airplay' || state.service == 'volspotconnect2' || state.service == 'radio_paradise' || (state.service == 'webradio' && self.config.get('tryScrobbleWebradio'))))
if((self.previousState.artist == state.artist) && (self.previousState.title == state.title) && ((self.previousState.status == 'pause' || self.previousState == 'stop') || initialize) || (self.currentTimer && !self.currentTimer.isPaused()) && (self.previousScrobble.artist != state.artist && self.previousScrobble.title != state.title))
self.logger.info('[LastFM] artist and song are (still) the same; but not necessarily no update.');
// Still the same song, but different status; continue timer is applicable, else start a new one | or the previousState has not yet been initialized.
self.updateNowPlaying(state);
if(state.duration > 0)
self.logger.info('[LastFM] playtime for current track: ' + self.playTime);
if(self.playTime > 0)
var remainingTime = scrobbleThresholdInMilliseconds - self.playTime;
self.logger.info('[LastFM] Continuing scrobble, starting new timer for the remainder of ' + remainingTime + ' milliseconds [' + state.artist + ' - ' + state.title + '].');
self.currentTimer.stop();
self.currentTimer.start(remainingTime, function(scrobbler){
self.logger.info('[LastFM] scrobbling from restarted timer.');
self.scrobble(state, self.config.get('scrobbleThreshold'), scrobbleThresholdInMilliseconds);
self.playTime = 0;
else
if(scrobbleThresholdInMilliseconds > 0)
self.logger.info('[LastFM] starting new timer for ' + scrobbleThresholdInMilliseconds + ' milliseconds [' + state.artist + ' - ' + state.title + '].');
self.currentTimer.start(scrobbleThresholdInMilliseconds, function(scrobbler){
self.playTime = 0;
else
self.logger.info('[LastFM] can not scrobble; state object: ' + JSON.stringify(state));
else if (state.duration == 0 && state.service == 'webradio')
self.logger.info('[LastFM] starting new timer for ' + scrobbleThresholdInMilliseconds + ' milliseconds [webradio: ' + state.title + '].');
self.playTime = 0;
if(initialize)
initialize = false;
else if (self.previousState.title == null || self.previousState.title != state.title)
// Scrobble new song
// self.logger.info('[LastFM] previous state: ' + JSON.stringify(self.previousState));
// self.logger.info('[LastFM] current state: ' + JSON.stringify(state));
self.logger.info('[LastFM] previous title does not match current title, evaluating timer settings...');
self.logger.info('[LastFM] timer is counting: ' + self.currentTimer.isCounting());
if(state.duration > 0 && (self.currentTimer && !self.currentTimer.isCounting()))
if(scrobbleThresholdInMilliseconds == undefined || scrobbleThresholdInMilliseconds == 0)
self.logger.info('[LastFM] state object: ' + JSON.stringify(state));
self.playTime = 0;
if(initialize)
initialize = false;
self.playTime = 0;
else
self.logger.info('[LastFM] duration is 0, ignoring status update for [' + state.artist + ' - ' + state.title + ']');
else if (self.previousState.artist == state.artist && self.previousState.title == state.title && self.previousState.duration != state.duration && self.currentTimer.isCounting())
// Airplay fix, the duration is propagated at a later point in time
var addition = (state.duration - self.previousState.duration) * (self.config.get('scrobbleThreshold') / 100) * 1000;
self.logger.info('[LastFM] updating timer, previous duration is obsolete; adding ' + addition + ' milliseconds.');
self.currentTimer.addMilliseconds(addition, function(scrobbler){
self.playTime = 0;
else
self.logger.info('[LastFM] could not process current state: ' + JSON.stringify(state));
// else = multiple pushStates without change, ignoring them
else if (state.status == 'pause')
if(self.currentTimer.isCounting())
self.playTime = self.currentTimer.pause();
else if (state.status == 'stop')
self.logger.info('[LastFM] stopping timer, song has ended.');
self.playTime = 0;
return libQ.resolve();
ControllerLastFM.prototype.getConfigurationFiles = function()
return [‘config.json’];
// Plugin methods -----------------------------------------------------------------------------
ControllerLastFM.prototype.onStop = function() {
var self = this;
self.logger.info(“performing onStop action”);
ControllerLastFM.prototype.stop = function() {
var self = this;
self.logger.info(“performing stop action”);
ControllerLastFM.prototype.onStart = function() {
var self = this;
self.logger.info(“performing onStart action”);
ControllerLastFM.prototype.onRestart = function()
var self = this;
self.logger.info(“performing onRestart action”);
ControllerLastFM.prototype.onInstall = function()
var self = this;
self.logger.info(“performing onInstall action”);
ControllerLastFM.prototype.onUninstall = function()
// Perform uninstall tasks here!
self.logger.info(“performing onUninstall action”);
ControllerLastFM.prototype.getUIConfig = function() {
var self = this;
var defer = libQ.defer();
var lang_code = this.commandRouter.sharedVars.get(‘language_code’);
self.logger.info(“Loaded the previous config.”);
var thresholds = fs.readJsonSync((__dirname + '/options/thresholds.json'), 'utf8', {throws: false});
self.commandRouter.i18nJson(__dirname+'/i18n/strings_' + lang_code + '.json',
__dirname + '/i18n/strings_en.json',
__dirname + '/UIConfig.json')
.then(function(uiconf)
self.logger.info("## populating UI...");
// Credentials settings
uiconf.sections[0].content[0].value = self.config.get('API_KEY');
uiconf.sections[0].content[1].value = self.config.get('API_SECRET');
uiconf.sections[0].content[2].value = self.config.get('username');
if(self.config.get('password') != undefined && self.config.get('password') != '')
uiconf.sections[0].content[3].value = self.config.get('password');
else
uiconf.sections[0].content[3].value = '******';
self.logger.info("1/3 settings loaded");
// Scrobble settings
for (var n = 0; n < thresholds.percentages.length; n++){
self.configManager.pushUIConfigParam(uiconf, 'sections[1].content[0].options', {
value: thresholds.percentages[n].perc,
label: thresholds.percentages[n].desc
if(thresholds.percentages[n].perc == parseInt(self.config.get('scrobbleThreshold')))
uiconf.sections[1].content[0].value.value = thresholds.percentages[n].perc;
uiconf.sections[1].content[0].value.label = thresholds.percentages[n].desc;
uiconf.sections[1].content[1].value = self.config.get('pushToastOnScrobble');
uiconf.sections[1].content[2].value = self.config.get('tryScrobbleWebradio');
uiconf.sections[1].content[3].value = self.config.get('webradioScrobbleThreshold');
self.logger.info("2/3 settings loaded");
uiconf.sections[2].content[0].value = self.config.get('enable_debug_logging');
self.logger.info("3/3 settings loaded");
self.logger.info("Populated config screen.");
defer.resolve(uiconf);
.fail(function()
defer.reject(new Error());
return defer.promise;
ControllerLastFM.prototype.setUIConfig = function(data) {
var self = this;
self.logger.info("Updating UI config");
var uiconf = fs.readJsonSync(__dirname + '/UIConfig.json');
ControllerLastFM.prototype.getConf = function(configFile) {
var self = this;
this.config = new (require(‘v-conf’))()
this.config.loadFile(configFile)
ControllerLastFM.prototype.setConf = function(conf) {
var self = this;
// Public Methods ---------------------------------------------------------------------------------------
ControllerLastFM.prototype.updateCredentials = function (data)
var self = this;
var defer=libQ.defer();
self.config.set('API_KEY', data['API_KEY']);
self.config.set('API_SECRET', data['API_SECRET']);
self.config.set('username', data['username']);
if(data['storePassword'] && data['passowrd'] != undefined && data['passowrd'] != '' && data['passowrd'] != '******')
self.config.set('password', data['password']);
self.config.set('authToken', md5(data['username'] + md5(data['password'])));
defer.resolve();
self.commandRouter.pushToastMessage('success', "Saved settings", "Successfully saved authentication settings.");
ControllerLastFM.prototype.updateScrobbleSettings = function (data)
var self = this;
self.config.set('scrobbleThreshold', data['scrobbleThreshold'].value);
self.config.set('pushToastOnScrobble', data['pushToastOnScrobble']);
self.config.set('tryScrobbleWebradio', data['tryScrobbleWebradio']);
self.config.set('webradioScrobbleThreshold', data['webradioScrobbleThreshold']);
defer.resolve();
self.commandRouter.pushToastMessage('success', "Saved settings", "Successfully saved scrobble settings.");
ControllerLastFM.prototype.updateDebugSettings = function (data)
var self = this;
self.config.set('enable_debug_logging', data['enable_debug_logging']);
defer.resolve();
self.commandRouter.pushToastMessage('success', "Saved settings", "Successfully saved debug settings.");
ControllerLastFM.prototype.updateNowPlaying = function (state)
var self = this;
self.updatingNowPlaying = true;
var artist = state.artist;
var title = state.title;
var album = state.album;
if(state.service == 'webradio' && state.title.indexOf('-') > -1)
var info = state.title.split('-');
artist = info[0].trim();
title = info[1].trim();
album = '';
if(state.service == 'radio_paradise')
if (
(self.config.get('API_KEY') != '') &&
(self.config.get('API_SECRET') != '') &&
(self.config.get('username') != '') &&
(self.config.get('authToken') != '') &&
artist != undefined &&
title != undefined &&
album != undefined
self.logger.info('[LastFM] trying to authenticate...');
var lfm = new lastfm({
api_key: self.config.get('API_KEY'),
api_secret: self.config.get('API_SECRET'),
username: self.config.get('username'),
authToken: self.config.get('authToken')
lfm.getSessionKey(function(result) {
if(result.success) {
self.logger.info('[LastFM] authenticated successfully!');
// Use the last.fm corrections data to check whether the supplied track has a correction to a canonical track
lfm.getCorrection({
artist: artist,
track: title,
callback: function(result) {
if(result.success)
// Try to correct the artist
if(result.correction.artist.name != undefined && result.correction.artist.name != '' && artist != result.correction.artist.name)
self.logger.info('[LastFM] corrected artist from: ' + artist + ' to: ' + result.correction.artist.name);
artist = result.correction.artist.name;
// Try to correct the track title
if(result.correction.name != undefined && result.correction.name != '' && title != result.correction.name)
self.logger.info('[LastFM] corrected track title from: ' + title + ' to: ' + result.correction.name);
title = result.correction.name;
else
self.logger.info('[LastFM] request failed with error: ' + result.error);
// Used to notify Last.fm that a user has started listening to a track. Parameter names are case sensitive.
lfm.scrobbleNowPlayingTrack({
artist: artist,
track: title,
album: album,
if(!result.success)
console.log("in callback, finished: ", result);
} else {
self.logger.info("[LastFM] Error: " + result.error);
else
// Configuration errors
if(self.config.get('API_KEY') == '')
self.logger.info('[LastFM] configuration error; "API_KEY" is not set.');
if(self.config.get('API_SECRET') == '')
self.logger.info('[LastFM] configuration error; "API_SECRET" is not set.');
if(self.config.get('username') == '')
self.logger.info('[LastFM] configuration error; "username" is not set.');
if(self.config.get('authToken') == '')
self.logger.info('[LastFM] configuration error; "authToken" is not set.');
//self.currentTimer = null;
ControllerLastFM.prototype.scrobble = function (state, scrobbleThreshold, scrobbleThresholdInMilliseconds)
var self = this;
var now = new Date().getTime();
album = '';
self.logger.info('[LastFM] checking previously scrobbled song...');
self.logger.info('[LastFM] previous scrobble: ' + JSON.stringify(self.previousScrobble));
if (
album != undefined
self.logger.info('[LastFM] trying to authenticate for scrobbling...');
if(result.success)
self.logger.info('[LastFM] authenticated successfully for scrobbling!');
lfm.getCorrection({
artist: artist,
track: title,
if(result.success)
//self.logger.info("[LastFM] callback, finished: ", JSON.stringify(result));
else
self.logger.info('[LastFM] preparing to scrobble...');
lfm.scrobbleTrack({
artist: artist,
track: title,
album: album,
if(!result.success)
if(album == '')
album = '[unknown album]';
if(self.config.get('pushToastOnScrobble'))
self.commandRouter.pushToastMessage('success', 'Scrobble succesful', 'Scrobbled: ' + artist + ' - ' + title + ' (' + album + ').');
self.logger.info('[LastFM] Scrobble successful for: ' + artist + ' - ' + title + ' (' + album + ').');
else
self.previousScrobble.artist = artist;
self.previousScrobble.title = title;
self.clearScrobbleMemory((state.duration * 1000) - scrobbleThresholdInMilliseconds);
else
function md5(string) {
return crypto.createHash(‘md5’).update(string, ‘utf8’).digest(“hex”);
ControllerLastFM.prototype.clearScrobbleMemory = function (remainingPlaytime)
var self = this;
self.memoryTimer = setInterval(function(clear)
self.previousScrobble.artist = ‘’;
self.previousScrobble.title = ‘’;
, remainingPlaytime);
P R E P A R A T I O N F O R F U T U R E F U N C T I O N A L I T I E S
ControllerLastFM.prototype.statePushed = function (timeLeft)
timer = setInterval(countdown, 1000);
function countdown() {
if (timeLeft == 0) {
clearTimeout(timer);
// scrobble
} else {
timeLeft–;
ControllerLastFM.prototype.getCurrentMac = function () {
var self = this;
var interfaces = os.networkInterfaces();
var macs = ;
var mac = ‘’;
try
//self.logger.info('###### INTERFACES: ' + JSON.stringify(interfaces));
for (var inter in interfaces)
if(!interfaces[inter][0].internal)
// Omit any 'empty' MAC address
if (interfaces[inter][0].mac != '00:00:00:00:00:00')
macs.push({ interface: inter, mac: interfaces[inter][0].mac });
// Sort by interface: eth0, eth1, ethx, wlan0, wlan1, wlanx etc.
macs.sort(function(a, b){
var compA = a.interface.toLowerCase(), compB = b.interface.toLowerCase()
if (compA < compB)
return -1
if (compA > compB)
return 1
return 0
//self.logger.info('########################### MACS: ' + JSON.stringify(macs));
currentMac = macs[0].mac;
self.logger.info('Determined MAC: ' + currentMac);
defer.resolve(mac);
catch(e)
self.logger.error('Could not determine MAC address with error: ' + e);
defer.reject();
};[/code]
Restart Volumio afterwards. Then start the flac version of radio paradise again, et voila:
I already got feedback from Saiyato, he will adapt it as soon as he’ll find the time (maybe already the coming weekend).
