[PLUGIN] Radio Paradise
Hi balbuze, Radio Paradise has added a new channel: Beyond, dedicated to jazz music. The link for FLAC is http://stream.radioparadise.com/beyond-flac
Can you add it?
Regars
Ok! I’ll have a look next week :wink:
edit : should be ok with Radio_paradise v2.0.14 for volumio Bookworm!
No luck for v3.x?
I guess it’s not very relevant, as v4 is coming soon.
Hi balbuze.
I’ve installed the plugin on bookworm and the Beyond stream works fine (as does bookworm, btw).
Alas, the metadata is totally out of sync, or, I would say, totally wrong. :slight_smile: Copy/Paste error maybe?
Thanks for the great plugin!
Hello!
You’re right!
It was not as simple, I rewrote a part of the code… but the fix is in Radioparadise V2.0.16 (Volumio 4 beta only)
Let me know
I’m not the author… But I keep it alive and update! :wink:
Works!
Thanks a lot.
I’m on V4.088 . running on a rpi4 and i have a touchscreen. When listening to Radio Paradise the screen is not is sync with what is playing. It seems the screen is displaying the upcoming track rather than the current track. Very annoying. Anywone else have this issue?
The main RP stream in FLAC is no longer working for me, from either the plug in or from the ā€œvolumio selectionā€. Also the AAC 320k main stream is playing something different from the other streams.
Is this a plug in issue or a RP issue or a me issue?
nothing changed on Volumio or plugin side.
And I have the same issue… even on their website!
So issue definitely from Radioparadise
Seems it’s up again
after being absent for a long time, I think about completeley refactoring my Radio Paradise Plugin for Volumio. I want to implement their api way of listening, not just a static stream and then hoping that the metadata’s timing matches somehow.
I’m a little bit lost on how to proceed here. My questions:
  1. Is plugin development for Volumio 4 in general still the same as described here in the developer documentation for Volumio 3?
  2. How can I update/change my Radio Paradise plugin concerning credentials/rights and how can I push beta updates only to the beta plugin channel before it’s ready for release? Does the plugin wizzard still work and can I convince him that I don’t want to create a new plugin but edit an existing one?
  3. Or should I just start from scratch and create a new plugin?
Thanks!
Hello @marco79cgn !
There’s no more updates for Volumio 3 plugins store.
You have to use GitHub - volumio/volumio-plugins-sources-bookworm now. Have a look at the readme.
Simply submit from a volumio 4 device, it will produce a beta version. If everything is ok, we will push it as stable.
Thanks :+1:
I would love to have this!
