[PLUGIN] Radio Paradise
Oh thank you! This is the requirered add to the base code.
edit the file radio_stations.json and add
“title”: “Radio 2050 (FLAC)”,
“uri”: “webrp/9”,
“url”: “http://stream.radioparadise.com/radio2050-flac ”
(it’s easy to find where to add it)
Radio paradise v1.0.10 stable
Added radio 2050
Update your plugin!
Enjoy :wink:
Thanks so much to both!
Hi ,
I have updated to latest version but when I press 2050 radio , normal radio paradise 128k version is played .
hello,
I checked in the plugin and confirm that the correct stream is used*…
        "title": "Radio Paradise Radio 2050 (FLAC)",
        "uri": "webrp/9",
        "url": "http://stream.radioparadise.com/radio2050-flac"
*stream given above [PLUGIN] Radio Paradise - #242 by jocoman
I can’t do more…
The difference I see is track info
I believe :slight_smile: but when I click it 128k mp3 default radio paradise is playing
Pls check also radio paradise aac 320k . When I press this station , 2050 station is played
Another strange behaviour , while listening to 2050 radio the display changes to main radio k paradise station :slight_smile:
There is no other change in the plugin than adding Radio 2050.
As I’m not the author or user, I just did what described…
  "stations": {
    "rparadise": [
        "title": "Radio Paradise Main Mix (FLAC)",
        "uri": "webrp/0",
        "url": "https://stream.radioparadise.com/flac"
        "title": "Radio Paradise Mellow Mix (FLAC)",
        "uri": "webrp/1",
        "url": "https://stream.radioparadise.com/mellow-flac"
        "title": "Radio Paradise Rock Mix (FLAC)",
        "uri": "webrp/2",
        "url": "https://stream.radioparadise.com/rock-flac"
        "title": "Radio Paradise World/Etc Mix (FLAC)",
        "uri": "webrp/3",
        "url": "https://stream.radioparadise.com/world-etc-flac"
        "uri": "webrp/9",
        "title": "Radio Paradise (AAC 320k)",
        "uri": "webrp/4",
        "url": "http://stream-uk1.radioparadise.com/aac-320"
        "title": "Radio Paradise (AAC 128k)",
        "uri": "webrp/5",
        "url": "http://stream-uk1.radioparadise.com/aac-128"
        "title": "Radio Paradise (AAC 64k)",
        "uri": "webrp/6",
        "url": "http://stream-uk1.radioparadise.com/aac-64"
        "title": "Radio Paradise (MP3 192k)",
        "uri": "webrp/7",
        "url": "http://stream-uk1.radioparadise.com/mp3-192"
        "title": "Radio Paradise (MP3 128k)",
        "uri": "webrp/8",
        "url": "http://stream-uk1.radioparadise.com/mp3-128"
Maybe something else needs to be changed…
I know … I just told the observed behaviour . Nevertheless I am not a fan of 2050 station .
but your right… I try to have a look…
Maybe RADIO 2050 needs to be the last radio due to
`webrp/9`
Radio paradise v 1.0.11
As I cant spend more time, I simply reordered radio 2050 at the end of the list… Not clean but ok :wink:
Hi
The good is that when I play radio 2050 , radio 2060 is started :slight_smile: but now the bad ; after a while the display is changed to default radio paradise … radio 2060 continue playing
Hi everyone
Radio Paradise plugin, album art and music info is no synchronized. Problem occurred a few days ago and persists. Any suggestions?
Hi. When I am listening to Radio Paradise, the first song has the countdown timer, after that its just sits as 00:00
Is there a setting I’m missing or is this a bug? any help would be appreciated.
txs
I really would like to get this fixed. Maybe I’m not posting the request for help in the right place. If so, where would i have better results in getting this resolved?
txs
Moderator: Can you move this post to the Radio Paradise plugin section. The timer works ok when I play music from my internal drive just NOT when listening to Radio Paradise. Thank-you
Radio Paradise has added a new channel: http://stream.radioparadise.com/serenity
Can you add it to the plugin?
Regards
Done in v1.0.13! :wink:
