Did reinstalling help? If not:
Under Volumio Network settings, is the correct IP reported?
If possible, capture some logs. Start logging → enter the plugin settings → stop logging.
Try stopping the plugin, wait for a while, then start the plugin again. See if the correct IP is shown.
The other two issues (weather and Genius) are possibly related to incorrect IP being obtained. So the first step in debugging this would be to get the correct IP shown in the plugin settings.
This is more likely to be a problem with Volumio itself. Now Playing and Peppymeter just display whatever album cover is reported by Volumio.
Reinstalled and the same issue.
Log in here:
http://logs.volumio.org/volumio/9I99ZsE.html
dvo
December 11, 2023, 3:20pm
540
both where set on my ip instead of localhost aka 127.0.0.1
tested on 3.512 / Rpi / now playing 0.5.4 / all works oke . getting http://<< my ip >>:4004/preview
… Updating to 3.569 …
tested on 3.569 / Rpi / now playing 0.5.4 / all works oke . getting http://<< my ip >>:4004/preview
no problems in opening it.
i don’t see it as a problem it’s a way to get the info outside your pi
What about the following?
patrickkfkan:
EDIT:
Actually, would like to test the following:
Stop Now Playing plugin
Go to Volumio Network settings - is correct IP reported?
Start Now Playing plugin and go to plugin settings - has the IP address changed to show the correct one?
dvo
December 11, 2023, 4:36pm
542
`# ifconfig ---------------
eth0: flags=4163 mtu 1500
inet 192.168.1.100 netmask 255.255.255.0 broadcast 192.168.1.255
ether a8:5e:45:a3:93:e6 txqueuelen 1000 (Ethernet)
RX packets 4041 bytes 794095 (775.4 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 5436 bytes 5515232 (5.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 43
this is showing his ip local partrick
I am aware of that, but that is the result of running ipconfig for the purpose of logging. It is not what I am asking for.
Hi @patrickkfkan ,
Done it. The IP was correct but this solution worked (stoped plugin, waited 2-3 mins, and restarted plugin).
It worked! Now I’ll try the other features of the plugin (weather, etc.) and report. Many thanks.
Now I manged to get weather and info working.
Great plugin! Thanks for the support on getting it to work.
This seems to reveal a Volumio bug where its getCachedIPAddresses() method returns the wrong values - perhaps due to the network interfaces not yet ready when the IP addresses were first read and cached. Going to Network Settings forces the cached IP addresses to refresh, so restarting the plugin after visiting Network Settings will allow the plugin to get the correct values.
Can you add the Tidal MQA logo? Thanks
ClaesM
February 1, 2024, 7:36am
548
Hi Patrick!
This morning weather data is not displayed? Any idea?
log: http://logs.volumio.org/volumio/mwU2bDT.html
eMCZe
February 1, 2024, 7:54am
549
Hi.
You are nor alone. It vanish about 6 hours ago.
I turn off and turn on plugin. Reinstall it. Still the same.
I have only date on the middle.
ClaesM
February 1, 2024, 8:10am
550
Hi!
Maybe it´s just a server down. Let’s wait for Patrick!
Regards/ C
OK, just pushed a quick fix. Please try again with v0.5.5 (currently in beta channel).
Remember to backup your config in plugin settings, before going through delete → install → restart.
ClaesM
February 1, 2024, 10:26am
553
Thanks for quick respons and fix! It works as supposed.
Regards / C
updated and it works again, thanks.
eMCZe
February 1, 2024, 3:11pm
555
Thank you from my wife. This morning she dasn’t know what to wear when going to work.
Now weather works again.
SimonE
February 1, 2024, 5:26pm
556
Thanks @patrickkfkan - all working again.
I was sure I’d screwed up something yesterday and spent a couple of hours trying to fix it. Glad I had a back up of the config!
