@patrickkfkan I have recently installed the mixcloud plugin. This works for the most part, but sometimes if I press the pause button (to continue playing after half an hour or so), everything locks up and volumio stops playing anything. I do not experience this issue while playing local files or files from my NAS.
In the logs I can read:
Aug 28 11:14 : ffmpeg/https: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b.m4a/seg-318-a1.ts' for reading
Aug 28 11:14 : alsa_output: Decoder is too slow; playing silence to avoid xrun
Aug 28 11:15 : alsa_output: Decoder is too slow; playing silence to avoid xrun
UPDATE: after a while, music starts playing again:
Aug 28 11:31 : ffmpeg/tls: Error in the pull function.
Aug 28 11:31 : ffmpeg/hls,applehttp: keepalive request failed for 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b.m4a/seg-318-a1.ts', retrying with new connection: Input/output error
Aug 28 11:31 : ffmpeg/hls,applehttp: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b.m4a/seg-318-a1.ts' for reading
Aug 28 11:31 : client: [0] closed
Aug 28 11:31 : ffmpeg/hls,applehttp: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b.m4a/seg-319-a1.ts' for reading
Aug 28 11:31 : ffmpeg/hls,applehttp: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b-192K.m4a/seg-318-a1.ts' for reading
Aug 28 11:31 : ffmpeg/hls,applehttp: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b-192K.m4a/seg-319-a1.ts' for reading
Aug 28 11:31 : ffmpeg/https: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b.m4a/seg-320-a1.ts' for reading
Aug 28 11:31 : ffmpeg/https: Opening 'https://audio13.mixcloud.com/secure/hls/6/a/7/f/b9fb-139b-4a4b-af00-5b687caeda7b-192K.m4a/seg-320-a1.ts' for reading
So, no idea what happened here ![]()
