Yes, another OLED plugin. The store was clearly suffering from a shortage. Before anyone sharpens a pitchfork, an apology, in public and in advance.
To @supercrab, @balbuze and Adrian Rossiter: mpd_oled put a spectrum on these little panels years ago, and plenty of players still run it happily. To @Zhapox: your SSD1309 plugin is tidy and I have no quarrel with it. To @olivier_audiophonics: the Evo Sabre and RaspDacMini displays are yours and stay yours. To Ax-LED and Faster3ck: Pirate Audio owners are in good hands. And to myself, co-author of the Evo Sabre and RaspDacMini LCD plugins, who now has some explaining to do to me.
Just OLED is not a fork of any of these and does not replace any of them. If one of them already does what you need, keep it.
It is also not for proper screens. If you have one of those, Glass, Glass-evo, Peppy, Now Playing, Touch Display and Stylish Player are where you want to be. This is the postage-stamp end of the market.
What it is
Spectrum, VU levels, the track and a clock on a small OLED, moving with the music. Under the hood:
- an audio tap in the ALSA chain that passes every stream through byte for byte and measures it on a thread of its own: files, radio, streaming, AirPlay and Spotify alike
- a small daemon that draws the pages over I2C or SPI, shows a standby clock and date with the player’s address, goes dark after a while, and puts boot, restart and shutdown messages on the panel
- the usual Volumio plugin for settings and player state
Faces: spectrum, stereo spectrum, spectrum with left and right levels, levels alone, the track alone in larger type, or the spectrum across the whole panel. Every page lays itself out for the panel it is on, from a 128x32 strip to a 256x64 greyscale or a 128x128 colour module.
What is new
I went through the Volumio 4 plugin sources before typing this: nothing else draws a stereo spectrum with left and right levels on one of these panels, and nothing else covers mono, greyscale and colour controllers in a single plugin.
The tap and the display daemon are written in Rust following the approach of my EVO Framework (https://evoframework.org): small single-purpose parts and a single external crate (libc). The approach only - there is no EVO code inside, and Just OLED is MIT licensed.
What it costs
Measured on a Pi 4 playing FLAC, stereo spectrum with levels, all parameters up, [PANEL], with top -H over 10 seconds:
- tap thread: 3.6% of one core
- display daemon: 0.7% of one core, 2.5 MiB resident
- together: about 1% of the Pi 4’s four cores
One thing to declare before someone finds it: the tap is an ALSA plugin, so it runs inside the player process. In plain top it is counted in mpd’s line; with top -H it shows as its own thread, justoledtap. The figure above is that thread, measured, not estimated. The screenshot below is from a Pi 4.
Where it stands
Version 0.1.3. The tap, the daemon, the faces and drivers for every common controller are in. One module has been seen working on the bench: the Waveshare 1.5in RGB OLED (SSD1351). The rest are driven from the data sheets, which is where you come in.
Controllers: SSD1306, SSD1309, SSD1315, SSD1305, SH1106, SH1107, SSD1327, SSD1322, SSD1325, SH1122, SSD1362, CH1120, and the colour SSD1331, SSD1351 and SSD1357.
Built to run on a Pi Zero 2 W, 3, 4 or 5 (32- or 64-bit image), or a PC with a USB I2C adapter.
Testers wanted
It is not in the plugin store yet. It goes there once it has been through field testing and Volumio’s review. Until then:
- download the zip from the releases page: Releases · foonerd/just_oled · GitHub
- install it by hand as the Quick Start shows: Quick Start · foonerd/just_oled Wiki · GitHub
- wire it from the drawings: Wiring · foonerd/just_oled Wiki · GitHub
Most wanted: anyone with a panel other than the SSD1351, and anyone with a Pi Zero 2 W.
When you report, please include:
- board and exact Volumio version
- panel: controller, size, I2C or SPI
- what you expected and what you saw
- a log link from http://volumio.local/dev (how: How to send a log link for a bug report? | Volumio)
- a photo of the panel if it is drawing something odd
Displays, settings and troubleshooting are all in the wiki: Home · foonerd/just_oled Wiki · GitHub
