My test setup, raspberry 2, ir receiver.
spotify plugin crashes each time by using the IR Remote. I tested my own lircrc and lircd.conf by putty, works fine.
I solved my problem i hope you can come back usefulā¦
I have a raspberry 2 with pifi-dac+ (grande accoppiata
grazie michelangelo sei grande
)and I managed to run it with the remote of Apple (A1294).
I think the problem is related to the fact that the plugin configuration file (lircd.conf) is incorrect for my system
I regenerated it:
And everything worked great
GPIO setting is really missing.
The lircd.conf for Cambridge Audio RC-651AC is attached. lircd.conf.zip (886 Bytes)
command for load playlist:
/usr/bin/curl āhttp://127.0.0.1:3000/api/v1/commands/?cmd=playplaylist&name=PlaylistNameā
Iāve got the same problem with this configuration (RPi3 + PiFi + A1156).
Any ideas?
I created a profile for my remote and now I want to create buttons (I have one of those fancy remotes with LCD) for my playlists.
Whatās the best way to load a playlist?
Iām doing it with MPC but Volumio doesnāt know something is playing and Pause/Stop donāt work.
Please donāt use mpc, but send commands directly to volumio. See here the API:
volumio.github.io/docs/API/WebSocket_APIs.html
I think I found the answer to my own question
:3000/api/v1/commands/?cmd=playplaylist&name=House
I noticed a problem with webradio and the play/pause function of my remote (ODroid). This will also be a problem with other remotes with only a play/pause button and no stop button.
Pushing play/pause when playing webradio pauses the stream instead of stopping it (which is what the GUI does), putting the player in the wrong state and preventing the user from restarting the stream with the remote.
I created a pull request with a fix.
Nice, the pull request was accepted.
I now created a pull request that enables repeating keys for volume and seek (i.e. holding volume up or down keeps changing it), and enables the power button to shutdown Volumio with the ODroid remote.
Youāre on fire!!!
I only use my Volumio to listen to webradio so the pause issue was really annoying. Thank you.
Youāre welcome
Just wanted to know if anyone has setup preset internet radio stations selection via RC6 remote. I have no problem using browser or android app to controlā¦but my parents are not tech savvy and want nothing to do with tablets or smart phones. They still use flip phones.
Just wondering how hard it would be to have a list of ten or so streaming internet stations that could be switch via an RC6 by pressing a number.
I use volumio for playing radio stations.
Set numbers to the command:
/usr/bin/curl "http://127.0.0.1:3000/api/v1/commands/?cmd=play&N=5"
N is the position of the radio station in the queue. First radio has N=0.
There are two bugs.
Radio names disappear after loading the playlist with radios. github.com/volumio/Volumio2/issues/1270
NEXT and PREV commands are not working if radio is playing github.com/volumio/Volumio2/issues/1251
Hi all
Great idea controlling Volumio with ir+remote.
However it will not work for meā¦this is what I did
Also tried a TSOP23438 - only 3,3V - and also tried GPIO 26, 18ā¦
Any help�
GREAT IDEA! This is about all Volumio needs to become the āperfectā music playback solution. I have found a couple of proposed solutions to use an IR remote with Volumio but all that I tried have failed, maybe because the are obsolete.
Waiting with impatience ![]()
Regards
LeVolatile
P.S. - btw I vought recently a JustBoom DAC and I am VERY satisfied with it. It sounds really good.
I can not update the plugin. I see this error.
The following error occurred when installing the plugin: Error
I have ordered a Justboom remote controller, and being a total noob on GPIO it took me a (short) while to install it.
What was tricky is that I had to actually āsaveā the configuration for the plugin (plugin => configuration => save) even if it was already set up as Justboom Remote. This was vicious, and it may be look up as an improvement
In the otherhand, the remote works fine and the plugin too. Iām very pleased with it
Iām currently working on mapping more mapping for the remote : power now enqueues my favorites radio, and I will map other buttons to playlists.
Have you guys thought of proposing advanced mapping option in the plugin configuration?
Last question: by doing some custom mapping, I have to modify the lircrc of the plugin itself. Is there any other clean way to do it? Because by doing this, the work will be erased on any plugin update. And if I want to share my work, it will be a modified plugin.
Best,
Cosmita
I had the same problem. I checked that my Apple Remote was the A1294 and got it working by replacing the file at
data/plugins/system_controller/ir_controller/configurations/Apple\ Remote\ A1294\lircd.conf
with the following (I can only assume either the provided lircd.conf is incorrect or there are multiple versions of the Apple remote):
begin remote
name /home/volumio/out.conf
bits 8
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9052 4439
one 586 1635
zero 586 536
ptrail 586
repeat 9059 2207
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0xD8
gap 106949
toggle_bit_mask 0x0
begin codes
KEY_MENU 0x40
KEY_PLAY 0x7A 0x20
KEY_LEFT 0x10
KEY_RIGHT 0xE0
KEY_UP 0xD0
KEY_DOWN 0xB0
KEY_ENTER 0xBA 0x20
end codes
end remote
Hi guys,
Sorry for the noob question: I just bought a IQaudIO Pi-DigiAMP+ that I put on top of my RPI3. Can you tell me if something like the TSOP4838 IR receiver can be mounted on it and used with the plugin?
Thanks for any pointer.
-j
