Ah ok! Thanks for the update!
What is my plugin like compared to the amp switcher? ![]()
Much much more refined, way more options, very flexible!
And unlike amp switcher that crashed Volumio at startup, it wonât toggle any GPIO until configuredâŠ
Wish I had found it sooner, It would have prevented me to lose a lot of time.
Thats great news indeed! Iâm glad you found it so helpful. Many thanks! ![]()
Hi Supercrab,
I just wanted to report a problem with GPIO control with Volumio 3.661 (premium subscription) on raspberry 5, 2gb.
Any config I try to implement with regard to events in the plugin, the save action button does not react (though it seems to keep my settings as if I quit then go back in, it has stored them) and the plugin keeps then locked in inactive state, though I set it on »ON » in the plugin main page.
If I undo all settings in the plugin and set them back all to off, then the plugin accept to be activatedâŠ
Log of the config is here : http://logs.volumio.org/volumio/Anxu3S9.html
Any hints on insight may be helpful - thanks a lot.
Benoit
Not sure off the top of my head, maybe itâs something to do with this line in the log
invalid GPIO 6
Can you try with a different GPIO?
Hi, I have tested several Gpio, low and high, and the result is the same.
@BenoitMarhieu Maybe itâs something to do with Raspberry Pi 5? I donât have a Raspberry Pi 5 to test this unfortunately. Are you able to test on a non Raspberry Pi 5?
It seems wiringpi is not working on rpi5.
See discussion in thread : https://forums.raspberrypi.com/viewtopic.php?t=359742
They recommand using gpiod, lgpio or gpiozero.
Any chance the plugin is ported to a more compatible and futureproof library?
Benoit
Wiringpi has been deprecated for a couple of years now.
Thanks for your help! You are correct sir!
Looks like GPIO has completely changed on Pi5.
Changing the library shouldnât be too bad, just have to decide which one is best. Not all of them have been ported to node.js ![]()
Iâve read that the library I used called onoff shoukd still work, not sure whats going on ![]()
yeah got the same impression.
I can test if needed, have a rPi5 for it.
It looks like the GPIO numbers have all changed and they now start at 399? That might explain why itâs not working. I think the onoff library does work.
$ cat /sys/kernel/debug/gpio
gpiochip4: GPIOs 399-452, parent: platform/1f000d0000.gpio, pinctrl-rp1:
gpio-399 (ID_SD )
gpio-400 (ID_SC )
gpio-401 (PIN3 )
gpio-402 (PIN5 )
gpio-403 (PIN7 )
gpio-404 (PIN29 )
gpio-405 (PIN31 )
gpio-406 (PIN26 )
gpio-407 (PIN24 )
gpio-408 (PIN21 )
gpio-409 (PIN19 )
gpio-410 (PIN23 )
gpio-411 (PIN32 )
gpio-412 (PIN33 )
gpio-413 (PIN8 )
gpio-414 (PIN10 )
gpio-415 (PIN36 )
gpio-416 (PIN11 )
gpio-417 (PIN12 )
gpio-418 (PIN35 )
gpio-419 (PIN38 )
gpio-420 (PIN40 )
gpio-421 (PIN15 )
gpio-422 (PIN16 )
gpio-423 (PIN18 )
gpio-424 (PIN22 )
gpio-425 (PIN37 )
gpio-426 (PIN13 )
gpio-427 (PCIE_RP1_WAKE )
gpio-428 (FAN_TACH )
gpio-429 (HOST_SDA )
gpio-430 (HOST_SCL )
gpio-431 (ETH_RST_N |phy-reset ) out hi ACTIVE LOW
gpio-432 (- )
gpio-433 (CD0_IO0_MICCLK |cam0_reg ) out lo
gpio-434 (CD0_IO0_MICDAT0 )
gpio-435 (RP1_PCIE_CLKREQ_N )
gpio-436 (- )
gpio-437 (CD0_SDA )
gpio-438 (CD0_SCL )
gpio-439 (CD1_SDA )
gpio-440 (CD1_SCL )
gpio-441 (USB_VBUS_EN )
gpio-442 (USB_OC_N )
gpio-443 (RP1_STAT_LED |PWR ) out hi ACTIVE LOW
gpio-444 (FAN_PWM )
gpio-445 (CD1_IO0_MICCLK |cam1_reg ) out lo
gpio-446 (2712_WAKE )
gpio-447 (CD1_IO1_MICDAT1 )
gpio-448 (EN_MAX_USB_CUR )
gpio-449 (- )
gpio-450 (- )
gpio-451 (- )
gpio-452 (- )
gpiochip3: GPIOs 453-458, parent: platform/107d517c00.gpio, gpio-brcmstb@107d517c20:
gpio-453 (HDMI0_SCL )
gpio-454 (HDMI0_SDA )
gpio-455 (HDMI1_SCL )
gpio-456 (HDMI1_SDA )
gpio-457 (PMIC_SCL )
gpio-458 (PMIC_SDA )
gpiochip2: GPIOs 459-475, parent: platform/107d517c00.gpio, gpio-brcmstb@107d517c00:
gpio-459 (RP1_SDA )
gpio-460 (RP1_SCL )
gpio-461 (RP1_RUN |RP1 RUN pin ) out hi
gpio-462 (SD_IOVDD_SEL |vdd-sd-io ) out lo
gpio-463 (SD_PWR_ON |sd_vcc_reg ) out lo
gpio-464 (SD_CDET_N )
gpio-465 (SD_FLG_N )
gpio-466 (- )
gpio-467 (2712_WAKE )
gpio-468 (2712_STAT_LED |ACT ) out hi ACTIVE LOW
gpio-469 (- )
gpio-470 (- )
gpio-471 (PMIC_INT )
gpio-472 (UART_TX_FS )
gpio-473 (UART_RX_FS )
gpio-474 (- )
gpio-475 (- )
gpiochip1: GPIOs 476-479, parent: platform/107d508500.gpio, gpio-brcmstb@107d508520:
gpio-476 (WIFI_SDIO_D0 )
gpio-477 (WIFI_SDIO_D1 )
gpio-478 (WIFI_SDIO_D2 )
gpio-479 (WIFI_SDIO_D3 )
gpiochip0: GPIOs 480-511, parent: platform/107d508500.gpio, gpio-brcmstb@107d508500:
gpio-480 (- )
gpio-481 (2712_BOOT_CS_N |spi10 CS0 ) out hi ACTIVE LOW
gpio-482 (2712_BOOT_MISO )
gpio-483 (2712_BOOT_MOSI )
gpio-484 (2712_BOOT_SCLK )
gpio-485 (- )
gpio-486 (- )
gpio-487 (- )
gpio-488 (- )
gpio-489 (- )
gpio-490 (- )
gpio-491 (- )
gpio-492 (- )
gpio-493 (- )
gpio-494 (PCIE_SDA )
gpio-495 (PCIE_SCL )
gpio-496 (- )
gpio-497 (- )
gpio-498 (- )
gpio-499 (- )
gpio-500 (PWR_GPIO |pwr_button ) in hi ACTIVE LOW
gpio-501 (2712_G21_FS )
gpio-502 (- )
gpio-503 (- )
gpio-504 (BT_RTS )
gpio-505 (BT_CTS )
gpio-506 (BT_TXD )
gpio-507 (BT_RXD )
gpio-508 (WL_ON |wl_on_reg ) out hi
gpio-509 (BT_ON |shutdown ) out hi
gpio-510 (WIFI_SDIO_CLK )
gpio-511 (WIFI_SDIO_CMD )
With GPIOD you can still use the pin numbers ![]()
Hereâs a snippet from a piece of Python I use:
import gpiod
BUTTON_PINA = 13
chip = gpiod.Chip('gpiochip4')
button_linea = chip.get_line(BUTTON_PINA)
button_linea.request(consumer="Button", type=gpiod.LINE_REQ_DIR_IN)
button_stateA = button_linea.get_value()
It looks good, I just canât find a decent node port of it ![]()
https://forums.raspberrypi.com/viewtopic.php?t=364182
On Pi5 just use ânew Chip(4)â instead of zero
Thanks a lot Wheaten and Supercrab for the follow up. Seems there is a way forward. Happy to test if a dev version is available.
Do have some concerns if the change is backwards compatible.
Maybe a check on HW is needed to determine the the board, in pseudo:
if rpi5 then ânew Chip(4)â
else ânew Chip(0)â
Iâve upgraded the plugin to use gpiox give it test when you can. Itâs a Beta plugin. Cheers!
did a quick test, but it doesnât seems to work.
The livelog doesnât show any event.
Placed buttons between
gnd and GPIO23 and GPIO24, switch both ON/OFF in plugin => no results
3.3V and GPIO23 and GPIO24, switch both ON/OFF in plugin => no results
