GPIO 3 works, but not GPIO 27,24, …
Does someone knows here which GPIO Pins are working with the Kali reclocker?
Thank you.
ok, it seems, only the high pull pins will work because pin 17 (3,3V) is not connected through kali.
high pull are GPIO Pin 2-8. using low pull with 5V directly, may damage the board.
did you search for it , because on de site of allo.com are al de tech documents (pinout/in) for the KALI RECLOCKER to download !!
yes, i found the documents for the kali. thats why i post a reply to my thread.
