if needed I can do:
- model name : 12th Gen Intel(R) Core™ i7-1255U
- model name : Intel(R) Atom™ x5-Z8350 CPU @ 1.44GHz
if needed I can do:
v1.09 update “Wheaten”
Changelog
Tested OK on volumio x86 over virtualbox
Waiting your feedback…
on RaspberryPi 4 everything is ok. v1.09
only the library analysis is slow…but that you do once
Seems to work as expected, but have to be very patient… 100 tracks per minute, took 12 hours to complete.
zlaja5 Wheaten maybe you should backup your database once finished in cas of
volumio, still need to give php a try to manage restore of the backup, then it will be ready to get official. Keep you in touch
For a near future I would love to bridge LMS and volumio a little but unfortunately (and surpisingly) I understand NOTHING to NodeJS despite of my readings
Maybe an effort to get “full stack” skills could be a good personal resolution for 2023
@ chourmovs_vs
yeah fully understand what your saying… Even I do (or better did) program Java and Javascript, I still miss the logic or the
with the node.js part.
For some reason it won’t stick. But I am patient, you’ll still have 21 days for the month is over
you’re too good
hehe, was thinking 10 days would be enough, but didn’t want to put pressure on you. So kind as I am, I gave you 11 extra days.
v1.10 update
Changelog
note : to get things working : 1) update plugin 2) uninstall plugin 3) reinstall plugin
needed to install php in place of nodejs http-server
Hope to read you soon!
Launch database backup
http://192.168.0.55:10005/
Unable to connect
Firefox can’t establish a connection to the server at 192.168.0.55:10005.
otherwise, everything else is working great ! v.1.1.0
did you uninstall then reinstall the plugin ? It’s mandatory to get php installed and address:10005 working
Sorry for the inconvenience,
No, I did a fresh install of volumio and your DstmMix plugin v.1.1.0…
Ok let me investigate… maybe firefox… keep you in touch
Ok got it reproduced, here is my fix
1 - restart volumio
2 - If not already done, install bliss tool that now also include php stuff
3 - desactivate/reactivate plugin to get ip adress duly found by balbuze IP snipet
It should work
It looks like php need the machine to restart to initiate
thank you for your feedback
new volumio v. 3.423 very big collection of music OLd plugin “Dont stop the music” is disabled with your DstmMix.
How to enable it ?
Hi my dear friend, I need to check
Zlaja in fact I don’t understand exactly what your problem is ?
Your screen shot make me feel you have an analysis problem … but your sentence “OLd plugin “Dont stop the music” is disabled with your DstmMix” refers to another problem isn’t it ?
I did the update today and I tested everything working as before
Can you be more explicit please ?
