volumio plugin install
This command will install the plugin on your device
Compressing the plugin
Plugin succesfully compressed
/bin/mv: inter-device move failed: ‘custom_autoplay.zip’ to ‘/tmp/plugins/custom_autoplay.zip’; unable to remove target: Permission denied
child_process.js:866
throw err;
Error: Command failed: /bin/mv *.zip /tmp/plugins/custom_autoplay.zip
at checkExecSyncError (child_process.js:790:11)
at execSync (child_process.js:863:15)
at install (/volumio/pluginhelper.js:767:9)
at Object.<anonymous> (/volumio/pluginhelper.js:862:9)
at Module._compile (internal/modules/cjs/loader.js:1085:14)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
at Module.load (internal/modules/cjs/loader.js:950:32)
at Function.Module._load (internal/modules/cjs/loader.js:790:12)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
at internal/main/run_main_module.js:17:47 {
status: 1,
signal: null,
output: [
null,
Buffer(0) [Uint8Array] ,
Buffer(139) [Uint8Array] [
47, 98, 105, 110, 47, 109, 118, 58, 32, 105, 110, 116,
101, 114, 45, 100, 101, 118, 105, 99, 101, 32, 109, 111,
118, 101, 32, 102, 97, 105, 108, 101, 100, 58, 32, 39,
99, 117, 115, 116, 111, 109, 95, 97, 117, 116, 111, 112,
108, 97, 121, 46, 122, 105, 112, 39, 32, 116, 111, 32,
39, 47, 116, 109, 112, 47, 112, 108, 117, 103, 105, 110,
115, 47, 99, 117, 115, 116, 111, 109, 95, 97, 117, 116,
111, 112, 108, 97, 121, 46, 122, 105, 112, 39, 59, 32,
117, 110, 97, 98,
… 39 more items
pid: 3036,
stdout: Buffer(0) [Uint8Array] ,
stderr: Buffer(139) [Uint8Array] [
117, 110, 97, 98,
… 39 more items
