Hello
I am trying to install the volstereo2mono.zip plugin.
I have downloaded with wget the zip in a temporary folder in Home and typed sudo volume plugin install.
I am stuck at 60% for 20 minutes now.
Did I make something wrong ?
This needs addressing to the plugin author: if it’s not picked up here on forum (and it probably won’t be because you don’t mention the plugin in the post title … hint ), then log a problem at the Github site github.com/balbuze/volumio-plug … tereo2mono
Can I also add that you need to give us as much information as possible so we can help … saying “here is the error” in your post and then not including it just doesn’t work
