Hello
I am trying to install the volstereo2mono.zip plugin.
I have downloaded with wget the zip in a temporary folder in Home and typed sudo volume plugin install.
I am stuck at 60% for 20 minutes now.
Did I make something wrong ?
This command will install the plugin on your device
Compressing the plugin
Plugin succesfully compressed
/bin/mv: cannot stat ‘*.zip’: No such file or directory
child_process.js:524
throw err;
Error: Command failed: /bin/mv .zip /tmp/plugins/volstereo2mono.zip
/bin/mv: cannot stat '.zip’: No such file or directory
at checkExecSyncError (child_process.js:481:13)
at execSync (child_process.js:521:13)
at install (/volumio/pluginhelper.js:663:9)
at Object.<anonymous> (/volumio/pluginhelper.js:723:9)
at Module._compile (module.js:570:32)
at Object.Module._extensions..js (module.js:579:10)
at Module.load (module.js:487:32)
at tryModuleLoad (module.js:446:12)
at Function.Module._load (module.js:438:3)
at Module.runMain (module.js:604:10)[/code]
/bin/mv: inter-device move failed: ‘volstereo2mono.zip’ to ‘/tmp/plugins/volstereo2mono.zip’; unable to remove target: Permission denied
throw err;
Error: Command failed: /bin/mv *.zip /tmp/plugins/volstereo2mono.zip
throw err;
