HI
I try to use my external dac , smsl M100, with Usb connexion to benefit the HW volum control.
In this case, in Hres >= 96khz I got some plops, clicks at the beginning of the track. Via toslink or via usb on my laptop I do not have such issue. So it looks the pb is the sync between RPI3B and the USB dac.
Below my system config
Is there a way, set up I can do to cover this issue ?
System Information
OS info
Version of Volumio: 3.512
Hostname: volumio
Kernel: 5.10.92-v7+
Governor: performance
Uptime: 0 days, 0 Hrs, 44 Minutes, 36 Seconds
Audio info
Hw audio configured: SMSL USB AUDIO
Mixer type: Hardware
Number of channels: 2
Board info
Model: Raspberry Pi 3 Model B Rev 1.2
Version: a02082
Firmware Version: Jan 20 2022 13:58:22 - bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
CPU info
Brand: BCM2837
Speed: 1.2Ghz
Number of cores: 4
Physical cores: 4
Average load: 9%
Temperature: 48°C
Memory info
Memory: 990020 Ko
Free: 50976 Ko
Used: 939044 Ko
Storage info
INTERNAL storage - Size: 11950Mo
Used: 1742Mo
Available for storage: 9588Mo (80%)
Close
