Playlists (volumio 2)
Hello! I am trying to import some playlists to my volumio but I cannot find where they go, I have tried going to
/var/lib/mpd/playlists/
(I shared this through samba)
but nothing is in there (even after I have created a playlist through volumio) and if I do put an m3u file in there it shows up in my music library. its empty looking at it through windows and if I putty my way to the folder and do a ls command its empty there as well.
At this point in time, Volumio does not support standard playlists such as m3u; it has it’s own internal format.
Where are they stored?
Have a look in:
/data/playlist
Ill check it out when I get a chance, thank you!
edit: this is the proper loc. ty again
