Hi, this is my first time on this forum and also my first time with Volumio.
The last Sunday I used a RPi with Volumio as a DJ on a party, it worked nice, but I missed the possibility to make a playlist and play it on Volumio. You know it is a hard task to build a playlist on Volumio.
The solution I just found is:
1 - Load all the music files to a Playlist using a Media Player like Clementine, where you can export playlists in .PLS format
2- Work on the music path to make sure it reads from the Pen Drive (I decided to leave the playlist on the same folder with my musics).
3 - Open Volumio and you will the Playlist on your USB files list.
4 - Add it and play.
What I miss was a way to loop my playlist…
Sandro
