Hi All, I’ve noticed that when the title exceeds the length of the “.playlist li” the web ui doesn’t look right (on my iphone) and titles overlap each other.
so I added “overflow:hidden;” to the “panels.css” on line 345 which kind of resolves the problem. I guess there’s a better way, my css is a bit rusty…
Hi, I have had this problem too. I changed /var/www/css/panels.css in the following ways to get them to auto size:
Around line 336, within the
.playlist li, .database li
block, set
height: auto;
and add
padding-bottom:10px;
at the end of the block.
Around line 373, within the
.playlist .pl-entry, .database .db-entry
block, set
height: auto;
and add add
Around line 378, within the
.database .db-folder, .database .levelup
block, set
height: auto;
and add add
This only works in Chrome for me, not Firefox. You’ll need to restart the web interface (or just the whole board). There must be a better way for the playlist list items to inherit the correct size.
