Playlist suddenly gets corrupted
I am a VOLUMIO PREMIUM user on Raspberry Pi 4 Model B 8GB RAM. It happens that after a few months of use the playlist gets corrupted. For example, I select a song from the playlist belonging to the local library and a different song from Qobuz, Spotify or always from the local library starts. In the past, thinking it was my problem, I formatted the card and started over. Now the problem has come back and it’s a bad thing… What does it depend on?
Tku
Hi Stefano,
premium users are entitled to dedicated support
From the helpdesk page, you can raise a ticket clicking on ASK FOR HELP button and following the chatbot flow : CREATE A REQUEST or CREATE NEW TICKET
Could you confirm that you have added only individual songs to a playlist and not an entire list of songs such as an album that is not from the local library?
May I suggest you test as follows:
  1. Add an album from a local library to a new playlist - do you see all songs in the album added to the playlist?
  2. Add an album from Spotify (or other source other than local library) to the same playlist - do you see only one new item added to the playlist?
  3. Now add another album from local library to the playlist
  4. Finally, in the playlist, select a song that is after the Spotify item. Does playback start with a different track?
