Playlist deleted at boot reappear
I login in myvolumio .
I delete same playlists, but when reboot raspberry its not deleted.
I don’t understand how deleted definitely
Inviato dal mio MI MAX 3 utilizzando Tapatalk
You are using MyVolumio’s ‘autosync’ feature.
Yes I know. But when i like to delete one or more playlists, what i must do ?
I think it is in the ‘todo’ list.
Please can you explain what i must do for delete definitely one playlist.
Excuseme for double posts, but i have many playlists to delete, but at boot its reappear.
I know that myvolumio sync its, but how delete definitely ?
You can’t at present permanently delete a playlist while using MyVolumio. A solution is being looked at but is not ready yet.
can-not-delet-item-favorites-t11856.html
I hope that developer will work to add options for deleted unwanted playlists…is not correct have many playlists, created first time that i use this software only for test…
Any preogres with that feature? It is really annoying that all unwanted playlists appear after reboot. Rename option would also a nice feature.
Again in this bug.
When you correct ?
Quando correggete l’errore!
Is not usefull that i have many playlists old and i can use this volumio frature!
Why ? Upgrade It.
non si possono cancellare le playlist e rimangono lì anche quelle vecchie così non è utilizzabile questa funzione ! Uno ha 1000 playlist e non sa quale aggiornata e quale no :blush:
