Hello
Thanks for the new version 2.565, I have already discovered some improvements. This is fantastic!
I have found a problem:
When I listen to the radio (SwissPop, for example) and then select the three dots under the circle on the left - “Go to Artist” to get the Artist in Qobuz, the system seems to restart completely.
I found that on a system with RPI 1 and RPI 3.
regards
rost21A
Thanks Rost, as always.
Your usage scenario is very interesting, we actually never thought about that and we’ll consider it ![:wink: :wink:](/images/emoji/apple/wink.png?v=9)
Perfect!
Thank you for your valuable work!
regards
rost21A
Hello Michelangelo
That would really be a brilliant feature if the artist search is taken over by a radio station in the general search. So you can get search results from your own music collection or better also from a mustik streaming service like Qobuz, Tidat, Spotify etc.
Let’s just hope that all the radio stations transmit the tags correctly.
Artist search from radio stations causes a problem.
Log: logs.volumio.org/volumio/BeiIgYw.html
regards
rost21A
