Hi your log is almost occupied with nothing else then:
Dec 04 21:26:21 volumio volumio[15736]: info: Discovery: Browse raised the following error Error: getaddrinfo -3007
Dec 04 21:26:32 volumio systemd-journald[202]: Suppressed 3235 messages from dbus.service
Dec 04 21:26:32 volumio dbus-daemon[464]: [system] The maximum number of active connections for UID 1000 has been reached (max_connections_per_user=256)
Dec 04 21:26:32 volumio volumio[15736]: info: Discovery: Browse raised the following error Error: dns service error: refused
If you connected wireless, please connect to a cabled connection and try again.
As I see a lot of DNS erros. What DNS servers have you programmed in your router? Please try those form google. Primary: 8.8.8.8 and secondary: 8.8.4.4
Dear Wheaten,
thank you for your help, I’m with a wired connection but I’m not able to change the dns configuration in my router because it is quite complicate to browse in the configuration page, I don want to make any mistakes.
Now I’m trying the new image that @volumio gave to me and seems to be working as aspected, if don’t, I will report here.
Dec 04 22:51:14 sala volumio[725]: |||||||||||||||||||||||| WARNING: FATAL ERROR |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Dec 04 22:51:14 sala volumio[725]: Error: getaddrinfo -3007
Dec 04 22:51:14 sala volumio[725]: at errnoException (/volumio/node_modules/mdns/lib/resolver_sequence_tasks.js:199:11)
Dec 04 22:51:14 sala volumio[725]: at getaddrinfo_complete (/volumio/node_modules/mdns/lib/resolver_sequence_tasks.js:112:10)
Dec 04 22:51:14 sala volumio[725]: at GetAddrInfoReqWrap.oncomplete (/volumio/node_modules/mdns/lib/resolver_sequence_tasks.js:120:9) {
Dec 04 22:51:14 sala volumio[725]: code: -3007,
Dec 04 22:51:14 sala volumio[725]: errno: -3007,
Dec 04 22:51:14 sala volumio[725]: syscall: 'getaddrinfo'
Dec 04 22:51:14 sala volumio[725]: }
Dec 04 22:51:14 sala volumio[725]: |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
It’s happening in networks which either have a device advertising a service via mdns, or a “shadow” mdns entry (due to abrupt shutdown of devices in the network).
This issue is quite hard to diagnose since in most networks it just works…
Dear all,
just an short update, changing the dns to google one (two to be more realistic), everything is fine, no more restart. Later I will change back the dns and I will put another sd with the beta image, in this way I can report if disabling the multiroom plugin let the system to be stable.
Dear all,
after revert the dns and installed the beta provided by Volumio, the result was an unstable system, with restarts every few seconds.
Than I disable the multiroom plug in and the system became stable.
Just for have the confirm that multiroom plugin was the guilty, I enable it again but the system remain stable than I reboot the raspberry and the system remain stable.
Here the log: http://logs.volumio.org/volumio/wu6rfcU.html
my network is
router D-link DVA 5592>
cable to floor 1> TP-Link TL-SG108E
Roon Server (I7 Asus rog)
Server Daphile (Assembled pc)
Apple AirPort Extreme
apple Time capsule
Fing Hardware
Game PC
Audio Rip PC
cable to floor 2> TP-Link TL-SG108E
Samsung TV
Cable to raspberry 4 (Volumio)
I hope it helps you understand what messes things up
