Play SACD ISO file with Volumio
Hi!
How can i play SACD ISO file with Volumio?
It is possible?
Thanks!
There are previous discussions of this on the forum.
It appears it is possible, but isn’t reliable/stable so far.
I am thinking of another solution for playing SACD ISO in Volumio.
Volumio has a Kodi Krypton plugin.
Kodi has a SACD ISO player plug-in:
This would allow SACD ISO playback within a system.
The problem is that in Volumio, Kodi is an older version 17.04.
The Kodi 17.04 repository does not include this Kodi plugin, only newer versions of Kodi.
How can I install this SACD ISO player Kodi plugin in Kodi version 17.04?
What are your views on this solution?
I don’t have any views on that.
I’d be ripping the SACD to DSF files and playing them.
You can rip the SACD iso image with Sonore https://www.sonore.us/iso2dsd.html and get DSD…
Thank you for your answers.
Impossible. I try to compile a MPD version with SACD iso support in volumio but I couldn’t. The only working solution is to extract the DSF files.
There’s a tool to extract the DSF files from an SACD .iso. It can be used by command line or its GUI.
https://www.videohelp.com/software/sacd-extract
I’ve created a tool which uses internally sacd_extract.exe. My tool is to convert multiple iso files and put the result in a determined output folder.
I’ll create a post.
