Hi There,
In version 2.114 I play DSD files flawlessly. 64 and 128 bit
Now the sound is stuttering only 1 second sound every 2 seconds.
I use Rapberry Pi 2B and Digiberry Pro
Playback options are: (working in version 2.114)
DSD over PCM, Off
Volume normalization, Off
Audio Buffer, 8 Mb
Buffer 10%
Persistent Que, Off
The DSP settings are new to me but this seems nothing to do with stutter less playing from DSD files.
I play a little with the playback options but no success.
What is the problem?
gkkpch
March 10, 2017, 5:27pm
2
Hi Pim,
is this all the time or only during library building?
– Gé –
Hi Gé,
In fact, it was during library building.
The strangest thing now…
Library building is done and now I have no sound at all???
Every file plays perfect but no DSD.
After rebooting I can play DSD but still stuttering.
Is there a way to go back to 2.114 or earlier?
Hi there,
Back to 2.041
DSD 2.82 and 5.64 Mhz play OK now.
gabram
March 29, 2017, 7:01pm
6
Hi Pim,
same setup as your, same tests, can’t play DSD files with version 2.129…
Hope next version will fix it…
GR
Hi all,
I have the same problem with PI3 and DAC+ Pro (Hi-Res FLAC are playing well).
Is there a way to download a previous version ? On the website only the last version seems available (or i’m too stupid to find it…) .
Anyway, thanks for the amazing work done on the software !
Seb
gkkpch
March 31, 2017, 7:34pm
8
This will need to be checked, as we are having issues with the mpd version.
There was an upgrade to mpd 20.4, but later reversed, not sure if the 20.4 version was actually published and reversed and therefore related to the problems you have.
Thanks for the answer. I checked mpd version, it’s 0.19.19 :
[code]volumio@volumio:~$ mpd -V
Music Player Daemon 0.19.19
Copyright © 2003-2007 Warren Dukes warren.dukes@gmail.com
Copyright © 2008-2014 Max Kellermann max@duempel.org
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
…[/code]
If you want me to test something on my RPI, let me know.
Seb
I encountered the issue and went back to 2.041 too. My audio configuration settings are the same as well.
Ed
FrankP
April 2, 2017, 12:07pm
11
Where did you download the 2.041 image ?
i can’t find it anywhere.
I took it off GitHub but can’t remember if this zipped file is the one, you can try: github.com/volumio/Volumio2/releases .
hong
April 15, 2017, 3:34am
14
I have the same problem to play DSD file after upgrade to the latest version.
livs
May 1, 2017, 6:56am
16
Test version 2.141 and it not work.
Can be solved with update to last version of mpd?
