Play album not possible on Raspberry Display Touch 7"
The three dot menu does not expand in the right direction making it not possible to select the available options, for example to play the whole album. Is this an user experience glitch in volumio?
For comparsion, here the same action on a notebook:
ibb.co/Cv6MScY
Here when using the official Raspberry Pi Touch Display 7", the menu expands to the top, no way to select the Play button, which makes most of the actions on a album or folder not usable.
ibb.co/y4hG3zT
Is this a know bug? Accepted UI Glitch?
Any suggestions? Thanks for some feedback.
R
It is a known issue:
https://forum.volumio.org/play-add-add-and-play-add-replace-update-this-folder-t6504.html
https://forum.volumio.org/raspberry-touchscreen-context-menu-not-accessible-t8437.html
https://forum.volumio.org/not-available-selection-menu-the-music-library-t8972.html
https://forum.volumio.org/folder-context-menu-not-fully-displayed-truncated-t9312.html
https://forum.volumio.org/android-volumio-app-dropdown-menu-t10168.html
Bug reports on Github:
https://github.com/volumio/Volumio2-UI/issues/248
https://github.com/volumio/Volumio2-UI/issues/524
Be aware that modifying .css files as described here will have the effect that system updates would not work anymore. You would have to delete userdata to be able to update and then apply the changes again.
